Floating Licence
  • New Member
Hi everyone,
I have a problem with a floating licence since last Wednesay (04/06/2022)
I'am still having a problem with 0/0 licence, our licence is not expired and has 2 floating licences normally,
I changed changed the firewall settings, set an admin account for the 3Dcoat services.
I still have the same problem
I have already sent an email to Serguii, but the email does not seem to be delivered. I received an error message from gmail.
Regards
Wednesday, 13 April 2022 10:39:25 | 3DCoat: FServer 1.16 Windows GUI (32-bit) started
Wednesday, 13 April 2022 10:39:25 | Port between 3DCoat and FServer is 8888
Wednesday, 13 April 2022 10:39:25 | Loaded license file "C:\3DCoat-FServer-1-16\license.dat"
Wednesday, 13 April 2022 10:39:25 | ----------------------------------------
Wednesday, 13 April 2022 10:39:25 | Found 2 interfaces for 3DCoat clients:
Wednesday, 13 April 2022 10:39:25 | IP:PORT 127.0.0.1:8888
Wednesday, 13 April 2022 10:39:25 | IP:PORT XXX.XX.XXX.XXX:8888
Wednesday, 13 April 2022 10:39:25 | Define on client machine(s) environment variable COAT_FSERVER with one of IP:PORT above
Wednesday, 13 April 2022 10:39:30 | Connecting to global license server 188.138.102.74 using port 80...
Wednesday, 13 April 2022 10:39:30 | Request code: 0A29DF17DF24A957D36F11DA9FC0826E4AFFC173538C78FF945834
Wednesday, 13 April 2022 10:39:30 | Request UHI: 3FBAEB1F
Wednesday, 13 April 2022 10:39:30 | Connected to global license server successfully
Wednesday, 13 April 2022 10:39:30 | Full response (1085 bytes):
HTTP/1.1 200 OK
Server: nginx
Date: Wed, 13 Apr 2022 08:39:30 GMT
Content-Type: text/html; charset=utf-8
Transfer-Encoding: chunked
Connection: close
X-Powered-By: PHP/7.3.33
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate
Pragma: no-cache
App-Made-By: thread-commerce.com
Set-Cookie: PHPSESSID=bu49t4m76gr06lhaeh7mkc4dg0; path=/; SameSite=Lax
Set-Cookie: tShopCart=66e6c9079d62b8dc6c680ab6225efe0e7ae3a195eb4ce50491f318de510992f8a%3A2%3A%7Bi%3A0%3Bs%3A9%3A%22tShopCart%22%3Bi%3A1%3Bs%3A32%3A%22HLCtHLrpUQRWueLei6eqCWurseo5iY_O%22%3B%7D; expires=Fri, 13-May-2022 08:39:30 GMT; Max-Age=2592000; path=/; HttpOnly; SameSite=Lax
Set-Cookie: article-showed=2d33a97c58fecc1202040dc87103fed1fce52f8427b9e222206849ceabb57364a%3A2%3A%7Bi%3A0%3Bs%3A14%3A%22article-showed%22%3Bi%3A1%3Bb%3A0%3B%7D; expires=Thu, 13-Apr-2023 08:39:30 GMT; Max-Age=31536000; path=/; HttpOnly; SameSite=Lax
X-Content-Type-Options: nosniff
X-Frame-Options: SAMEORIGIN
Cache-Control: public
X-Powered-By: PleskLin
8
32F3C7DA
0
Wednesday, 13 April 2022 10:39:30 | Hex response: 22220684
