New Member JoffreyB Posted April 13, 2022 New Member Report Share Posted April 13, 2022 Hi everyone, I have a problem with a floating licence since last Wednesay (04/06/2022) I'am still having a problem with 0/0 licence, our licence is not expired and has 2 floating licences normally, I changed changed the firewall settings, set an admin account for the 3Dcoat services. I still have the same problem I have already sent an email to Serguii, but the email does not seem to be delivered. I received an error message from gmail. Regards Wednesday, 13 April 2022 10:39:25 | 3DCoat: FServer 1.16 Windows GUI (32-bit) started Wednesday, 13 April 2022 10:39:25 | Port between 3DCoat and FServer is 8888 Wednesday, 13 April 2022 10:39:25 | Loaded license file "C:\3DCoat-FServer-1-16\license.dat" Wednesday, 13 April 2022 10:39:25 | ---------------------------------------- Wednesday, 13 April 2022 10:39:25 | Found 2 interfaces for 3DCoat clients: Wednesday, 13 April 2022 10:39:25 | IP:PORT 127.0.0.1:8888 Wednesday, 13 April 2022 10:39:25 | IP:PORT XXX.XX.XXX.XXX:8888 Wednesday, 13 April 2022 10:39:25 | ---------------------------------------- Wednesday, 13 April 2022 10:39:25 | Define on client machine(s) environment variable COAT_FSERVER with one of IP:PORT above Wednesday, 13 April 2022 10:39:30 | Connecting to global license server 188.138.102.74 using port 80... Wednesday, 13 April 2022 10:39:30 | Request code: 0A29DF17DF24A957D36F11DA9FC0826E4AFFC173538C78FF945834 Wednesday, 13 April 2022 10:39:30 | Request UHI: 3FBAEB1F Wednesday, 13 April 2022 10:39:30 | Connected to global license server successfully Wednesday, 13 April 2022 10:39:30 | Full response (1085 bytes): HTTP/1.1 200 OK Server: nginx Date: Wed, 13 Apr 2022 08:39:30 GMT Content-Type: text/html; charset=utf-8 Transfer-Encoding: chunked Connection: close X-Powered-By: PHP/7.3.33 Expires: Thu, 19 Nov 1981 08:52:00 GMT Cache-Control: no-store, no-cache, must-revalidate Pragma: no-cache App-Made-By: thread-commerce.com Set-Cookie: PHPSESSID=bu49t4m76gr06lhaeh7mkc4dg0; path=/; SameSite=Lax Set-Cookie: tShopCart=66e6c9079d62b8dc6c680ab6225efe0e7ae3a195eb4ce50491f318de510992f8a%3A2%3A%7Bi%3A0%3Bs%3A9%3A%22tShopCart%22%3Bi%3A1%3Bs%3A32%3A%22HLCtHLrpUQRWueLei6eqCWurseo5iY_O%22%3B%7D; expires=Fri, 13-May-2022 08:39:30 GMT; Max-Age=2592000; path=/; HttpOnly; SameSite=Lax Set-Cookie: article-showed=2d33a97c58fecc1202040dc87103fed1fce52f8427b9e222206849ceabb57364a%3A2%3A%7Bi%3A0%3Bs%3A14%3A%22article-showed%22%3Bi%3A1%3Bb%3A0%3B%7D; expires=Thu, 13-Apr-2023 08:39:30 GMT; Max-Age=31536000; path=/; HttpOnly; SameSite=Lax X-Content-Type-Options: nosniff X-Frame-Options: SAMEORIGIN Cache-Control: public X-Powered-By: PleskLin X-Powered-By: PleskLin 8 32F3C7DA 0 Wednesday, 13 April 2022 10:39:30 | Hex response: 22220684 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 13, 2022 Report Share Posted April 13, 2022 Hello Your problem was reported to Sergii Kryzhanovskyi at support.linux@pilgway.com Cheers Quote Link to comment Share on other sites More sharing options...
SERGYI Posted April 13, 2022 Report Share Posted April 13, 2022 Please contact me by email: support.linux@pilgway.com. Provide your online floating serial and number of seats. 1 Quote Link to comment Share on other sites More sharing options...
New Member JoffreyB Posted April 14, 2022 Author New Member Report Share Posted April 14, 2022 Hi Sergyi, Hi sent you an email with the information. Regards 1 Quote Link to comment Share on other sites More sharing options...
SERGYI Posted April 14, 2022 Report Share Posted April 14, 2022 1 hour ago, JoffreyB said: sent you an email with the information. Received and answered. Quote Link to comment Share on other sites More sharing options...
