New Member stephano Posted April 25, 2022 New Member Report Share Posted April 25, 2022 Hi, I have a kind of basic UI request concerning the stroke lasse color (sculpt room). By default, it's set to a semi-transparent green (#7FFF7F) but can't be changed in the theme color settings. The problem is that the green color is barely visible on brighter materials so it's difficult to perform precise cuts or selections. The stroke lasso tool is the one that I use 90% of the time because I mainly cut/pose/vox-hide things. I have a default mid-gray shader for sculpting so the green lasso stroke isn't eye-friendly and you can't clearly see the shape of the cuts/selections while drawing with the stroke stool. It would be great if we could define the stroke color or if there would be a different behavior for lasso strokes. For example, in Photoshop, the color of the lasso tool is set to the affecting background color, just inverted. That way, you will always clearly see the lasso shape. Another option would be a "black shadow" or an offsetted black doubled stroke that would support the default green stroke color. This would already help to see the stroke shapes better. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
