Member Refin_ken Posted May 27, 2022 Member Report Share Posted May 27, 2022 Якщо попробувати відкрити на пряму з файла збереження, програма видає помилку - видалити і скачати програму не допомогло Но якщо запустити саму програму і з неї сам файл то все працює If you try to open directly from the save file, the program gives an error - uninstall and download the program did not help But if you run the program itself and the file itself, then everything works Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 27, 2022 Report Share Posted May 27, 2022 Hi Are you using latest version 2022.28 ? Try adding this file on C:\Program Files\3DCoat-2022 Check if any antivirus is blocking it. Hope it help freetype.dll Quote Link to comment Share on other sites More sharing options...
Member Refin_ken Posted May 27, 2022 Author Member Report Share Posted May 27, 2022 I sent only one screenshot, there are three errors with dll files, but all these files are in the folder with the program, the replacement does not give anything. This error started after this situation: "I had an open 3d max and 3d coat, I worked in the coat, but at one point the RAM ran out and the 3D coatclosed with an error" after this message error Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 27, 2022 Report Share Posted May 27, 2022 May be broken installation file ? Download again from here please And run 3DC as administrator Quote Link to comment Share on other sites More sharing options...
Member Refin_ken Posted May 27, 2022 Author Member Report Share Posted May 27, 2022 nope, dont working, im uninstall and install coat, but not working Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 27, 2022 Report Share Posted May 27, 2022 I forwarded your issue but Please write this problem to andrewshpagin@gmail.com Quote Link to comment Share on other sites More sharing options...
