Fixing AppLink for Blender 3.8 after upgrading
wendallhitherd
Hello! I was asked to mirror the process I found for un-borking my 3DCoat applink. Hopefully someone will find this helpful! Original post found here:
From the jump:
Hey there! I just finally got the applink to work, after a whole bunch of struggling. The main issue is that old versions of 3dcoat interfere with new ones. The secret is:
- Delete every applink related folder out of my docs. both the app link and 3DC seems to write text files which contain path strings
-- if any of these files contain a reference to an old directory either 3DC or blender will automatically recreate that old folder.
- Deleting every applink folder includes, in my case:
C:\Users\<username>\Documents\3DC2Blender
C:\Users\<username>\Documents\3DCoat\Exchange
C:\Users\<username>\Documents\AppLinks
- Open 3DCoat and close it. This will respawn the 3DC exchange folder. (C:\Users\<username>\Documents\3DCoat\Exchange)
- Open Blender and plug in the freshly spawned exchange folder to Blender plugin exchange path. I was able to leave the object / texture empty
- Send a Voxel object to 3DC. This will spawn C:\Users\<username>\Documents\3DC2Blender folder.
- In 3DC, autopo, automap, and use "export to -> blender". As far as I can tell this will cause 3DC to spawn the C:\Users\<username>\Documents\AppLinks\3D-Coat\Exchange\Blender folder. Choose any fbx name you want.
- Export preset should be either Blender Cycles or BlenderAppLink. I used BlenderAppLink
- Back in Blender, click the "GetBack" button. This will spawn the object exported from 3DC and hook up the PBR shader!
As a side note I think the applink code on the blender side is hardcoded to spawn 3D-CoatV4 folder, as it keeps popping up after I delete it when I use "get back" out of blender. Luckily it doesn't seem to interfere with anything so long as the initial setup is clean.
  • Like 3
You wouldn't happen to have a recording of the process at all would you? I've spent the day trying to fix this and end up getting caught on one or two things along the way.
Ok, so I have tried following as best I can, but each time I open 3DC, I still get the warning message followed by a window that says C:\Users\(my user)\Documents\3DCoat - 2022>powershell Start -File "C:\Users\(my user)\Documents\3DCoat\data\temp\copy_applink.bat" -Verb RunAs
Is this normal?
  • 2 weeks later...
Carlosan
wendallhitherd was awarded the badge 'Helpful' and 1 points.
Is this normal?
I don't think so! You might have some permissions issues or an antivirus blocking 3DC / blender producing folders? TBH I don't know how it works under the hood
  • 9 months later...
Saved me! I was starting to get annoyed to the point that I did a fresh install of Blender and 3D Coat. But that didn't work. So I tried your method and now everything is back to normal. Orientation and scale of the model remains the same. Originally, the model was facing the wrong way.
  • 1 year later...
10 minutes ago, Andrew Shpagin said:
3DCoat uses folders
c:/User/usrname/Documents/AppLinks/
c:/User/usrname/Documents/3DC2Blender/
to exchange data, check if it exists
What version of blender you installed? Was you offered to update applink in 3DCoat (this is super important)?
Was the Blender installed into default folder? (generally coat seeks for Blender everywhere)
  • 3 weeks later...
  • New Member
Carlosan
Miljan Bojovic was awarded the badge 'Helpful' and 1 points.
This worked for me!
Thank you!
For my situation, after deleting those folder, opening 3D-Coat, it respawned the folder in C:\Users\<username>\Documents\AppLinks\3D-Coat\Exchange
Then I opened Blender, went to settings, searched "3D-Coat" in the plugins and set the ExchangeFolder to the new folder 3D-Coat respawned in Documents.
Now it works again :D
Hope this is helpful. :)
