Member wendallhitherd Posted May 28, 2022 Member Report Share Posted May 28, 2022 Hello! I was asked to mirror the process I found for un-borking my 3DCoat applink. Hopefully someone will find this helpful! Original post found here: From the jump: """ Hey there! I just finally got the applink to work, after a whole bunch of struggling. The main issue is that old versions of 3dcoat interfere with new ones. The secret is: - Delete every applink related folder out of my docs. both the app link and 3DC seems to write text files which contain path strings -- if any of these files contain a reference to an old directory either 3DC or blender will automatically recreate that old folder. - Deleting every applink folder includes, in my case: C:\Users\<username>\Documents\3DC2Blender C:\Users\<username>\Documents\3DCoat\Exchange C:\Users\<username>\Documents\AppLinks - Open 3DCoat and close it. This will respawn the 3DC exchange folder. (C:\Users\<username>\Documents\3DCoat\Exchange) - Open Blender and plug in the freshly spawned exchange folder to Blender plugin exchange path. I was able to leave the object / texture empty - Send a Voxel object to 3DC. This will spawn C:\Users\<username>\Documents\3DC2Blender folder. - In 3DC, autopo, automap, and use "export to -> blender". As far as I can tell this will cause 3DC to spawn the C:\Users\<username>\Documents\AppLinks\3D-Coat\Exchange\Blender folder. Choose any fbx name you want. - Export preset should be either Blender Cycles or BlenderAppLink. I used BlenderAppLink - Back in Blender, click the "GetBack" button. This will spawn the object exported from 3DC and hook up the PBR shader! As a side note I think the applink code on the blender side is hardcoded to spawn 3D-CoatV4 folder, as it keeps popping up after I delete it when I use "get back" out of blender. Luckily it doesn't seem to interfere with anything so long as the initial setup is clean. """ 3 1 Quote Link to comment Share on other sites More sharing options...
Member I_was_a_Bullfrog Posted May 29, 2022 Member Report Share Posted May 29, 2022 You wouldn't happen to have a recording of the process at all would you? I've spent the day trying to fix this and end up getting caught on one or two things along the way. Quote Link to comment Share on other sites More sharing options...
Member I_was_a_Bullfrog Posted May 30, 2022 Member Report Share Posted May 30, 2022 Ok, so I have tried following as best I can, but each time I open 3DC, I still get the warning message followed by a window that says C:\Users\(my user)\Documents\3DCoat - 2022>powershell Start -File "C:\Users\(my user)\Documents\3DCoat\data\temp\copy_applink.bat" -Verb RunAs Is this normal? Quote Link to comment Share on other sites More sharing options...
Member wendallhitherd Posted June 10, 2022 Author Member Report Share Posted June 10, 2022 This post was recognized by Carlosan! wendallhitherd was awarded the badge 'Helpful' and 1 points. On 5/29/2022 at 8:52 PM, I_was_a_Bullfrog said: Ok, so I have tried following as best I can, but each time I open 3DC, I still get the warning message followed by a window that says C:\Users\(my user)\Documents\3DCoat - 2022>powershell Start -File "C:\Users\(my user)\Documents\3DCoat\data\temp\copy_applink.bat" -Verb RunAs Is this normal? I don't think so! You might have some permissions issues or an antivirus blocking 3DC / blender producing folders? TBH I don't know how it works under the hood Quote Link to comment Share on other sites More sharing options...
Member Archnila Posted March 21, 2023 Member Report Share Posted March 21, 2023 Saved me! I was starting to get annoyed to the point that I did a fresh install of Blender and 3D Coat. But that didn't work. So I tried your method and now everything is back to normal. Orientation and scale of the model remains the same. Originally, the model was facing the wrong way. 1 Quote Link to comment Share on other sites More sharing options...
