Member frmdbl Posted May 30, 2022 Member Report Share Posted May 30, 2022 Hi, I just upgraded to 3dcoat 2022 and I can't find the 'Invert Tool' checkbox. Where is it? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 2, 2022 Report Share Posted June 2, 2022 Hi On voxel mode all new Clay Engine brushes have that option active when you press Ctrl+LMB 1 Quote Link to comment Share on other sites More sharing options...
Member frmdbl Posted June 2, 2022 Author Member Report Share Posted June 2, 2022 1 hour ago, Carlosan said: Hi On voxel mode all new Clay Engine brushes have that option active when you press Ctrl+LMB Yeah, so I can't make a negative brush preset, I have to always keep Ctrl pressed? Seriously? Someone thought it was a good idea to just remove that option completely? If that's the case it's unbelievable. 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 2, 2022 Report Share Posted June 2, 2022 Your request was forwarded to support team. Will be helpful if you drop a line about feature requests at support@pilgway.com Thanks 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member Elemeno Posted June 2, 2022 Advanced Member Report Share Posted June 2, 2022 i dont want an invert tool in the ui... its just clutter Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted June 2, 2022 Reputable Contributor Report Share Posted June 2, 2022 1 hour ago, Elemeno said: i dont want an invert tool in the ui... its just clutter No, it's not, actually. I use a 3DConnexion device and I prefer to check INVERT in the Toolbar, so I don't have to stop (using the Navigation puck) in order to hold down the CTRL key. 2 1 Quote Link to comment Share on other sites More sharing options...
Contributor alexn007 Posted June 3, 2022 Contributor Report Share Posted June 3, 2022 @AbnRanger I'm in total agreeance with you! I also use the 3DConnexion space mouse and having the invert option is a must. I would like to see it back in the ui. Thanks! 1 1 Quote Link to comment Share on other sites More sharing options...
Member frmdbl Posted June 3, 2022 Author Member Report Share Posted June 3, 2022 10 hours ago, Elemeno said: i dont want an invert tool in the ui... its just clutter So you're saying that for example when you want a brush that makes grooves/cuts like 'Dam Standard' in Zbrush, you'd prefer to always keep ctrl pressed rather that just use the pen? I'm really not sure how to politely comment this, I really struggle to believe you can be this shortsighted. Besides I can live without it being in that exact spot, as long as it's there in the tool options panel for example. 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member Melik Posted June 6, 2022 Advanced Member Report Share Posted June 6, 2022 Just want to add that I would also really appreciate the option to invert a brush so I don't have to keep CTRL pressed. In the latest 3DC, only a random number of Voxel Tool brushes have the toolbar "Invert" option. Like OP, I don't understand the thinking behind this. Beyond the convenience for users to do large areas of inverted brushing, this option would also be essential if we're trying to create a custom brush preset that behaves in the inverted form of the original brush. I can't find an "Invert" parameter in the Tool Options/Modifiers for brushes either. If not in the toolbar, the invert brush option should be in the menus somewhere (so we can assign a hotkey). 2 Quote Link to comment Share on other sites More sharing options...
Solution Carlosan Posted December 29, 2022 Solution Report Share Posted December 29, 2022 On version 2022.55 Invert option was restored Invert tool action checkbox for the surface/voxel brush engine - based tools. Quote Link to comment Share on other sites More sharing options...
Member Jones C Posted April 14, 2023 Member Report Share Posted April 14, 2023 Sorry if this js not related to the topic, but is there a way i can set the "Ctrl" to "Alt" to invert the brush behavior? Quote Link to comment Share on other sites More sharing options...
