Member echoform Posted June 4, 2022 Member Report Share Posted June 4, 2022 Hello, Is anyone else getting this issue? It's happened on my install for about the last 3-4 updates. I was hoping they would go away, but it's persisting. Basically, a lot of the shaders are showing up black. I searched the forum and it looked like it was an issue a couple of years ago. I am using v2022.29 on Windows 10 with latest updates. Thank you for any insights. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 4, 2022 Report Share Posted June 4, 2022 Hi what happens if you use the command Refresh all previews (RMB)? Quote Link to comment Share on other sites More sharing options...
Member echoform Posted June 4, 2022 Author Member Report Share Posted June 4, 2022 Thank you for the suggestion. That did not update it. The shader itself it displaying all meshes as black. It is more than just the thumbnails. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 4, 2022 Report Share Posted June 4, 2022 Drivers. Win10 and graphic drivers are uptodate ? Quote Link to comment Share on other sites More sharing options...
Member echoform Posted June 5, 2022 Author Member Report Share Posted June 5, 2022 As far as I can tell, drivers are up to date...I just need to know if anyone else is having this issue or it could just be a local issue on my end. If no one has reported anything like this, I will try and reinstall from scratch. Thank you. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 5, 2022 Report Share Posted June 5, 2022 I got this issue once, the solution was to do a fresh install. before I renamed the folder (/documents/3dcoat/) to avoid losing my libraries and to be able to load them to the new folder. Quote Link to comment Share on other sites More sharing options...
Member echoform Posted June 5, 2022 Author Member Report Share Posted June 5, 2022 I will be doing that. Thank you. 1 Quote Link to comment Share on other sites More sharing options...
