Member Staglaitor Posted June 25, 2022 Member Report Share Posted June 25, 2022 Hello While retopo i use add/split tool and when i press shift button and move mouse i see strange result as if retopo mesh is duplicated but i can't do anything with it - what is it - how can it be useful? Thanks bandicam 2022-06-25 22-45-40-882.mp4 Quote Link to comment Share on other sites More sharing options...
Solution Andrew Shpagin Posted June 26, 2022 Solution Report Share Posted June 26, 2022 You pressed SHIFT and it shows the preview for the "close hole". It looks a bit strange, I will correct the preview. 2 Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted June 26, 2022 Reputable Contributor Report Share Posted June 26, 2022 23 hours ago, Staglaitor said: Hello While retopo i use add/split tool and when i press shift button and move mouse i see strange result as if retopo mesh is duplicated but i can't do anything with it - what is it - how can it be useful? Thanks bandicam 2022-06-25 22-45-40-882.mp4 When you pressed SHIFT, what were you intending to do with that hotkey? Clone? Quote Link to comment Share on other sites More sharing options...
