Advanced Member tokikake Posted June 26, 2022 Advanced Member Report Share Posted June 26, 2022 (edited) So I loved update manager, it can easy up-date to new version without change my 3d coat directory. But today I got inform when launch I can up date to new version. Then I try to up-date by up-date manager (install and run), It say Installed success.. Then I launch 3d coat from short-cut,, but it not work. then I check install directory.. And found up-date manager remove my 3d coat .exe file. When I test update manager to 3d coat 2022 32. it worked. but today update to 2022 .33 it seems not up-date correctly, but remove exe files or it seems simply miss something. (I confirm there are exe and I launched it to use up-date manager from 3d coat ) Edited June 27, 2022 by tokikake Quote Link to comment Share on other sites More sharing options...
Advanced Member tokikake Posted June 26, 2022 Author Advanced Member Report Share Posted June 26, 2022 I used this option. in install manager update page. Install and check integrity of the 3DCoat 2022.33 Then manager seems simply remove my exe, (2022.32) file . do not know other files was up-dated correctly or not. At current I manually download and installed 2022.33 in same directory, then it worked though... I report this. (I may not hope to test donwload manager untill I know clear reason why it happend,,) Quote Link to comment Share on other sites More sharing options...
Solution Carlosan Posted June 26, 2022 Solution Report Share Posted June 26, 2022 Hi, do you have any antivirus active ? Try downloading the file from here Quote Link to comment Share on other sites More sharing options...
Advanced Member tokikake Posted June 26, 2022 Author Advanced Member Report Share Posted June 26, 2022 4 hours ago, Carlosan said: Hi, do you have any antivirus active ? Try downloading the file from here I already have downlaoded manually from development thread and install. so it not effect my work now. I now consider if my antivirus interfere to auto update. I already set 3d coat exe and user library as exception directory and files in my antivirus soft setting. So 3d coat can run without problem. Maybe I need to set another directory as exception for anti virus, to auto update, I suppose. but do not know which directory or file need to set as exception for auto update. maybe I try again with set anti virus soft hidden, when next up-date. I could up-date with update manager once, but do not remember, if I de-activated antivirus at that time. 1 Quote Link to comment Share on other sites More sharing options...
Member retutca Posted June 27, 2022 Member Report Share Posted June 27, 2022 Hi,the web installation also deletes the exe files for me (2022.33). But the manual installation was successful from development thread! Thx. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 28, 2022 Report Share Posted June 28, 2022 Update to version .34 it is not working and still delete the exe file ? Quote Link to comment Share on other sites More sharing options...
