Advanced Member jene Posted July 1, 2022 Advanced Member Report Share Posted July 1, 2022 now I am using 3DCoatPrint2022.34. I can't find "auto pick" . where is it ? Quote Link to comment Share on other sites More sharing options...
Reputable Contributor Silas Merlin Posted July 1, 2022 Reputable Contributor Report Share Posted July 1, 2022 3 minutes ago, jene said: now I am using 3DCoatPrint2022.34. I can't find "auto pick" . where is it ? Quote Link to comment Share on other sites More sharing options...
Advanced Member jene Posted July 1, 2022 Author Advanced Member Report Share Posted July 1, 2022 17 minutes ago, Silas Merlin said: Hi,Silas. reply thank you. it is not 3D-coat full version. it is new "3D-COAT PRINT" version. now I am trying 3D-COAT PRINT . Quote Link to comment Share on other sites More sharing options...
Reputable Contributor Solution Silas Merlin Posted July 1, 2022 Reputable Contributor Solution Report Share Posted July 1, 2022 (edited) 6 hours ago, jene said: Hi,Silas. reply thank you. it is not 3D-coat full version. it is new "3D-COAT PRINT" version. now I am trying 3D-COAT PRINT . Here is a thing I would try... a "hack" of sorts I guess. but if it works, since this is a public space.... well, the ability might be removed by the powers that be. anyway, try this : Install and open the full version of 3d-Coat. Create a keyboard shortcut for "auto pick" (hover over the box and press the END key, then your key combination). Now, close 3d-Coat and open 3d-Coat-print and try the shortcut. If it does not work, it may mean that 3d-Caot-print and 3d-Coat are not using the same folder in documents. If that is the case, locate the options_hotkeys.xml file in both, and duplicate the entry for the auto pick shortcut from one to the other. Or, you can skip all of the above and simply insert this in your options_hotkeys.xml fils : <OneHotKey> <ID>AutoPick</ID> <Room>Voxels</Room> <Code>0</Code> <Ctrl>false</Ctrl> <Alt>false</Alt> <Shift>true</Shift> <AllowStack>false</AllowStack> <UserDefined>1</UserDefined> </OneHotKey> the shortcut here being SHIFT+0 (that's zero, not the letter o) PS: I don't know if 3d-Coat-print has a specific room other than "voxels", if so, just remove the word Voxels from the xml above. Edited July 1, 2022 by Silas Merlin 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member jene Posted July 2, 2022 Author Advanced Member Report Share Posted July 2, 2022 (edited) 14 hours ago, Silas Merlin said: Here is a thing I would try... a "hack" of sorts I guess. but if it works, since this is a public space.... well, the ability might be removed by the powers that be. anyway, try this : Install and open the full version of 3d-Coat. Create a keyboard shortcut for "auto pick" (hover over the box and press the END key, then your key combination). Now, close 3d-Coat and open 3d-Coat-print and try the shortcut. If it does not work, it may mean that 3d-Caot-print and 3d-Coat are not using the same folder in documents. If that is the case, locate the options_hotkeys.xml file in both, and duplicate the entry for the auto pick shortcut from one to the other. Or, you can skip all of the above and simply insert this in your options_hotkeys.xml fils : <OneHotKey> <ID>AutoPick</ID> <Room>Voxels</Room> <Code>0</Code> <Ctrl>false</Ctrl> <Alt>false</Alt> <Shift>true</Shift> <AllowStack>false</AllowStack> <UserDefined>1</UserDefined> </OneHotKey> the shortcut here being SHIFT+0 (that's zero, not the letter o) PS: I don't know if 3d-Coat-print has a specific room other than "voxels", if so, just remove the word Voxels from the xml above. thank you for your advice! I will try that. Edited July 2, 2022 by jene Quote Link to comment Share on other sites More sharing options...
Reputable Contributor Silas Merlin Posted July 5, 2022 Reputable Contributor Report Share Posted July 5, 2022 On 7/2/2022 at 10:43 AM, jene said: thank you for your advice! I will try that. I installed 3dc-print just now and tested what I suggested.... Sadly, it does not work. To me the auto pick makes the whole software unusable. 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member jene Posted August 15, 2022 Author Advanced Member Report Share Posted August 15, 2022 this problem seems to be fixed in 3D-coatPrint current version. I can find "auto pick". it is convenient. thank you Mr Andrew and development stuff. 1 Quote Link to comment Share on other sites More sharing options...
