2022.34 for Mac OS does not start up - look here
Posted (edited)
Just installed 2022.34 for Mac OS, but it does not start up. I get a very generic error message saying it can't start because of "a problem". I should add that 2022.24 did not have this issue.
The more detailed error report says the following:
Process:               3DCoat [1038]
Path:                  /Applications/3DCoat-2022.34/3DCoat.app/Contents/MacOS/3DCoat
Identifier:            com.Pilgway.-DCoat
Version:               2022.34 (1)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           3DCoat [1038]
User ID:               501
Date/Time:             2022-07-01 18:41:22.986 +0200
OS Version:            Mac OS X 10.14.6 (18G9323)
Report Version:        12
Anonymous UUID:        A38AB001-9F22-EA23-E1C0-C70E30BA0D5B
Time Awake Since Boot: 1100 seconds
System Integrity Protection: enabled
Crashed Thread:        0
Exception Type:        EXC_CRASH (SIGABRT)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Reason:    DYLD, [0x1] Library missing
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
  Library not loaded: @rpath/libosdGPU.3.4.4.dylib
  Referenced from: /Applications/3DCoat-2022.34/3DCoat.app/Contents/MacOS/3DCoat
  Reason: no suitable image found.  Did find:
    /Applications/3DCoat-2022.34/3DCoat.app/Contents/MacOS/../Frameworks/libosdGPU.3.4.4.dylib: cannot load 'libosdGPU.3.4.4.dylib' (load command 0x80000034 is unknown)
    /Applications/3DCoat-2022.34/3DCoat.app/Contents/MacOS/../Frameworks/libosdGPU.3.4.4.dylib: stat() failed with errno=1
Binary Images:
       0x103168000 -        0x105163ed7 +com.Pilgway.-DCoat (2022.34 - 1) <3ACB055C-BB9F-3A59-9FEF-3F9C1DC3285C> /Applications/3DCoat-2022.34/3DCoat.app/Contents/MacOS/3DCoat
       0x115ef5000 -        0x115f5f70f  dyld (655.1.1) <4842B61A-B868-3146-9CA9-5582C4198B25> /usr/lib/dyld
Model: MacPro6,1, BootROM 428.140.7.0.0, 8 processors, 8-Core Intel Xeon E5, 3 GHz, 32 GB, SMC 2.20f18
Graphics: kHW_AMDFireProD500Item, AMD FirePro D500, spdisplays_pcie_device, 3 GB
Memory Module: DIMM1, 8 GB, DDR3 ECC, 1866 MHz, 0x80AD, 0x484D54343147553741465238432D52442020
Memory Module: DIMM2, 8 GB, DDR3 ECC, 1866 MHz, 0x80AD, 0x484D54343147553741465238432D52442020
Memory Module: DIMM3, 8 GB, DDR3 ECC, 1866 MHz, 0x80AD, 0x484D54343147553741465238432D52442020
Memory Module: DIMM4, 8 GB, DDR3 ECC, 1866 MHz, 0x80AD, 0x484D54343147553741465238432D52442020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x135), Broadcom BCM43xx 1.0 (7.77.61.3 AirPortDriverBrcmNIC-1305.12)
Bluetooth: Version 6.0.14d13, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en2
PCI Card: AMD FirePro D500, Display Controller, Slot-1
PCI Card: AMD FirePro D500, Display Controller, Slot-2
Serial ATA Device: APPLE SSD SM0512F, 500,28 GB
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB 3.0 Bus
USB Device: Hub
USB Device: CodeMeter-Stick
USB Device: Balance
USB Device: iRig Keys
USB Device: Hub
USB Device: EIZO USB HID Monitor
USB Device: Razer Nostromo
USB Device: Intuos5 touch M
Thunderbolt Bus: Mac Pro, Apple Inc., 19.2
Edited by Andreas Wolmer
Forgot some information
After investigation and meeting, the USD library has been temporarily removed from "3DCoat/Textura/Print" under macOS. We will add "USD" later using a completely different approach. New builds "3DCoat/Textura/Print 2022.35" for macOS have been uploaded:
https://pilgway.com/~sergyi/links-macOS.html
"3DCoat/Textura/Print 2022.35" should run on older macOS versions.
  • Carlosan changed the title to 2022.34 for Mac OS does not start up - look here
  • Carlosan pinned this topic
