Help me!!!!! Why is baking in 3D Coat so difficult?
Water
  • New Member
Hello and good evening. I discovered this wonderful software called 3D Coat; I love the texturing and uv mapping workflows, but I can't seem to get a handle on the baking phase. I've tried several bakes, but each time the results are the same. Could somebody tell me why my bake looks like that and what I need do? I paid close attention to both the outside and interior cages. I've watched several tutorials, but to no avail. Help, what should I do to fix this?
Is the problem having to do with snapping problems? Maybe some step caused all of these and it would be good to turn off AUTO SNAP at the top of the UI to keep this from happening. Snapping can go haywire when the vertices are right up against the edge of a mesh or opening of a mesh. That is why it is good to know how to avoid these kinds of issues.
  • New Member
I tried it, but yet to no avail. The baking is still not working properly, even for basic models such as a bevelled cube. I really appreciate your efforts, AbnRanger and i'm still open to trying other techniques
Can you possibly screen record the process where it seems to fail? Perhaps we can spot what the issue is, by seeing it happen.
  • New Member
Good evening AbnRanger. so sorry that I didn't send a video, rather, I will be send a google drive link. I believe you will be able to inspect it better through there.
https://drive.google.com/drive/folders/1cOBFoBiuC57cMFD1SYxFqwmP4xvCmspN?usp=sharing
