New Member Kaen Posted July 30, 2022 New Member Report Share Posted July 30, 2022 (edited) I'm trying to use the Vox Clay tool and just a round brush, But it only gives a square? I tried other brushes and it does the same thing. I tried the same thing on 3DCoat v4 and it doesn't do that there. Is this a bug or have I done something wrong? All I have done is installed the software and went to start using it. Hopefully I'm posting in the right place and I apologize if I haven't posted in the right spot. Edit: Really need to get this working right or work out if I have done something wrong as I need to use this program for school. And am missing classes because of this issue. Teachers are using 3DCoat V4 which none of us can get and the school is unable to give to us either. Edited August 13, 2022 by Kaen Added info 1 1 Quote Link to comment Share on other sites More sharing options...
Solution Andrew Shpagin Posted September 3, 2022 Solution Report Share Posted September 3, 2022 Vox Clay is very specific brush, it does not use alpha intentionally. Instead, you may use any of Voxel Engine brish that may use alpha and similar to this brush. Look the Clay brushes, enable dependence on alpha in brush settings. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted September 6, 2022 Reputable Contributor Report Share Posted September 6, 2022 On 7/30/2022 at 3:55 AM, Kaen said: I'm trying to use the Vox Clay tool and just a round brush, But it only gives a square? I tried other brushes and it does the same thing. I tried the same thing on 3DCoat v4 and it doesn't do that there. Is this a bug or have I done something wrong? All I have done is installed the software and went to start using it. Hopefully I'm posting in the right place and I apologize if I haven't posted in the right spot. Edit: Really need to get this working right or work out if I have done something wrong as I need to use this program for school. And am missing classes because of this issue. Teachers are using 3DCoat V4 which none of us can get and the school is unable to give to us either. The default Clay Engine brushes use a default alpha, so check USE CURRENT ALPHA to enable usage of different custom brush alphas. You can find this option at the bottom of the MODIFIERS section of the Tool Panel Quote Link to comment Share on other sites More sharing options...
