[Fixed] Freeze tool in Surface mode issues
If you Freeze an area of a shape with the brush and then use the clay brush, Freeze works as expected.
However, right after that do a ctrl+d to clear the Freeze selection and reselect (Freeze) with the rectangle. Now switch back to the clay brush and the Frozen area is not respected.
If you start right away with the rectangle selection, there's no issues, it's only if you change selection mode. I havent tried all permutations. So far I can reproduce with brush select first and then rectangle select
Anyone else getting this?
Thanks.
Thanks.
cant seem to replicate this...
freeze working as it should my end
I tried to reproduce it this morning and couldnt, I was very puzzled.. Dug deep in memory..
So sometimes I'm doing ctrl+z to undo mask instead of using ctrl+d.. Muscle memory and all..
Then I was able to reproduce. Make sure you're using the humanoid, it's easier to reproduce than with the sphere for some reason.
It also takes a few times of File\New.. Try and and it works as expected, then File New and you can reproduce. It's a tricky one
49 minutes ago, Nossgrr said:
No worries, it's a tricky bug.
But at least it seems to work most time than not so it's not a deal breaker.
i got it... yea... never realised before,
the freeze tool is super bugged... its same for clay brushes or bevel tool...
even if you clear it ,its still bugged
only work around is to voxel mesh and then back and try again...
but this is quite a problem as i use freeze tools alot on zbrush and blender
  • Carlosan changed the title to [Bug] Freeze tool in Surface mode issues
  • Carlosan changed the title to [Fixed] Freeze tool in Surface mode issues
