New Member Beaull Posted August 11, 2022 New Member Report Share Posted August 11, 2022 I am trying to figure out why the snake tool in 3dcoat is removing mesh instead of adding it, has anyone else had this problem? Quote Link to comment Share on other sites More sharing options...
Contributor Solution alexn007 Posted August 12, 2022 Contributor Solution Report Share Posted August 12, 2022 (edited) This post was recognized by Carlosan! alexn007 was awarded the badge 'Helpful' and 1 points. In the voxels space the Snake tool has the option to invert the tool from the top menu strip, which is like pressing the Ctrl key. Or from the brush's tool options panel you can have voxHide enabled, which will also hide your voxels. Are either of these options enabled? That's all I can think of that would result to what you are describing. Cheers. Edited August 12, 2022 by alexn007 Quote Link to comment Share on other sites More sharing options...
New Member Beaull Posted August 15, 2022 Author New Member Report Share Posted August 15, 2022 This helped alot, thank you Alexn007. : ) 1 Quote Link to comment Share on other sites More sharing options...
Contributor alexn007 Posted August 15, 2022 Contributor Report Share Posted August 15, 2022 Glad it was helpful Quote Link to comment Share on other sites More sharing options...
