Alpha brush issue
phoenixart
Go to solution Solved by phoenixart,
I'm having a couple of brush issue.
The first one happens apparently for no reason on some alpha brush only.
In come cases, the border of the alpha brush is applied to the operation.
As for the second issue, the alpha brush seems to work only on a small area, as shown in the screen capture below:
Edited by phoenixart
  • Carlosan changed the title to [Bug] Alpha brush issue
Thanks @Elemeno
In my case, the fix is not working, I only get the high depth applied.
On top of that, now I'm experiencing a new issue: is there some sort of limit to how many brushes I can add to a folder?
I added several brushes to an existing folder, only to later realize they were gone.
Then, I created a new folder, but even in this case it only stored 14 new brushes (on top of the 6 default ones).
17 hours ago, Carlosan said:
No... there isnt any limits (2022.41)
Then it must be a bug, brushes keep disappearing.
This time, I took a screenshot of the brushes I added, as I thought I was imagining things.
So, here are the brushes I added before closing 3d Coat:
And this is what I found when I reopened it:
One brush is missing, and the order has changed.
Is there an automatic order that works only when 3d Coat is restarted?
And what happened to the missing brush?
It keeps doing this, and I can't figure out why.
Edit: I see now what happened. Two of the brushes I added are the same. I didn't notice it at first as the order isn't organized automatically, but only after 3d Coat is restarted.
  • Carlosan changed the title to Alpha brush issue
