Advanced Member phoenixart Posted September 14, 2022 Advanced Member Report Share Posted September 14, 2022 I don't think this is the expected result. I would think the result would be a straight line, instead I get a wobbly line. Is there some other parameters I should check? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 14, 2022 Report Share Posted September 14, 2022 Try cleaning up using RMB over the layer and > To Global Scape Quote Link to comment Share on other sites More sharing options...
Advanced Member phoenixart Posted September 14, 2022 Author Advanced Member Report Share Posted September 14, 2022 Hey @Carlosan The scale is uniform. It also happens regardless of the resolution. 2022-09-14 10-04-45_H.264_TC.mp4 Does it work as expected on your end? Quote Link to comment Share on other sites More sharing options...
Advanced Member Elemeno Posted September 14, 2022 Advanced Member Report Share Posted September 14, 2022 its happening the same my end... bug stamp approved 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member phoenixart Posted September 14, 2022 Author Advanced Member Report Share Posted September 14, 2022 Thanks for checking, and confirming @Elemeno! 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 14, 2022 Report Share Posted September 14, 2022 is how it works, following the surface topology. if you need straight lines need to use Plane Tool. Quote Link to comment Share on other sites More sharing options...
Advanced Member Elemeno Posted September 15, 2022 Advanced Member Report Share Posted September 15, 2022 its not properly following topology... vox hide should follow the line you create, if you use a brush then it follows correctly but the line tool doesnt Quote Link to comment Share on other sites More sharing options...
Advanced Member Elemeno Posted September 15, 2022 Advanced Member Report Share Posted September 15, 2022 Desktop 15-09-2022 20-02-46.mp4 also steady stroke doesnt work with vox hide Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 15, 2022 Report Share Posted September 15, 2022 Try turning OFF steady stroke, 120 is very high value (max default is 15) Quote Link to comment Share on other sites More sharing options...
