'decimate, auto-map, export' does not work at once
OhGwan
This is a really cool feature, and it's what I wanted. Thank you 3d coat team !!!
But there is a little problem. It does not work at once.
The model was extracted at once, but the texture was obtained after three extractions.
Sometimes the texture is extracted at once.
I don't know what's the standard, what's the reason. The settings are the same.
I did the same thing as this video, but is there anything I missed?
0:10 - 0:27
Edited by OhGwan
4 hours ago, Carlosan said:
Hi
I am testing version 2022.46 and everything is exporting ok.
Are you testing a single model with any default export preset ?
Surface or voxel ? or multiobjects... ? please share your export steps.
Thanks
Surface Mode
I think Single, Multi object doesn't matter.
I'm using 3DCoat 2022.46 version. in Sculpt Panel.
1 try
2 try ( changed UV)
3 try
4 try
This time I fail to export.
Edited by OhGwan
2 hours ago, Carlosan said:
Try selecting textures export path please.
It was extracted at once!
It can be extracted only when I set the texture path
Thank you very much.
I thought it would be automatically saved to the same path as the object without setting it like youtube video.
  • Carlosan changed the title to [Solved] 'decimate, auto-map, export' does not work at once
I've been trying this method for a few days, but it's completely random.
Even if I set the texture path, there are times when I succeed and times when I fail.
Is there any other way than 'decimate, auto-map, export'?
  • OhGwan changed the title to 'decimate, auto-map, export' does not work at once
  • 3 weeks later...
On 9/30/2022 at 5:34 AM, Andrew Shpagin said:
I discovered that if you have some object in scene, say "Volume5" and there is layer with the same name "Volume5". And you painted some color over the layer "Volume5". In this case the color from the layer "Volume5" will not be baked because this layer used to bake base color of the shader and it overwrites the painted color.
Please check if this is your case.
If no, please help me a bit more - make some video that demonstartes the issue. Every detail important, so fullscreen video is the best.
Oh I see.
And I tried with two computer. and both have same result.
two computer has AMD cpu process. I think It will be problem.
thank you for your answer and sorry for my bad english!
And I tried object and layer not same name. It's work at once!
But It also can be completly random. so I will try more and recording video someday.
Edited by OhGwan
I treid several time but it automactly create texture layer same name with Object name. (completly random)
  • 1 year later...
Same Issue here. Wrote Andrew mutliple times about it. Baking/Cage display gets ignored/skipped most of the time. Models come out fine , always, but textures are empty. Very sad this feature is not reliable 90% of the time.
I tried everything, no repro pattern I could hold on to. No reliable workarounds. It makes this otherwise amazing function eat away time and nerves.
Edited by Henry Townshend
correct
