Member foremancr Posted September 15, 2022 Member Report Share Posted September 15, 2022 Each time I open up 3d coat I must find the licene file and I can then use the program. Why doesn't it remember the licene file. 3D coat linux 2022.45 Quote Link to comment Share on other sites More sharing options...
SERGYI Posted September 18, 2022 Report Share Posted September 18, 2022 Please log in into our site:https://pilgway.com/user/login (in case you don't know the password click "Forgot your password?") There on tab "LICENSES/ACCOUNTS" click "DOWNLOAD LICENSE". On "3DCoat 2022" startup click button "Load license" and select the downloaded license-file. If the problem persists contact me directly by email "sergkryzh AT gmail dot com". Quote Link to comment Share on other sites More sharing options...
Member foremancr Posted September 18, 2022 Author Member Report Share Posted September 18, 2022 I have a downloaded copy of my password text file from your website whereby when I open 3d coat I then navigate to the "download license" text file where I click on it and all is well. The thing is when I open 3d coat again, I have to repeat the same process over again and again Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 18, 2022 Report Share Posted September 18, 2022 Are you installing as administrator ? Quote Link to comment Share on other sites More sharing options...
Member MagnusL Posted September 22, 2022 Member Report Share Posted September 22, 2022 (edited) I had a weird issue where things weren't saved on exit but i had an old trial version installed i hadn't removed prior getting my full license. Removing all installed software, cleaning out my registry with CC cleaner, rebooting and installing the latest build of 3DC was the trick.. Maybe your issue is the same.. Edited September 22, 2022 by MagnusL Removed non applicable tip Quote Link to comment Share on other sites More sharing options...
Member Spacecookie Posted September 28, 2022 Member Report Share Posted September 28, 2022 (edited) Hello, I keep having the same problem. I have downloaded the license file, and it's in the same directory as 3dcoat. Every time it opens it asks for the license. I click the 'Use license' button and it's right here in the directory. Edited September 28, 2022 by Spacecookie Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 2, 2022 Report Share Posted October 2, 2022 Try Help > Uninstall license close and open 3DC and install license again. Quote Link to comment Share on other sites More sharing options...
