Member Refin_ken Posted October 2, 2022 Member Report Share Posted October 2, 2022 after the calculation AmbientOcculions, the entire object turned black The calculation was very long, as if I use 16x anti-aliasing, after the calculation everything became black Quote Link to comment Share on other sites More sharing options...
Advanced Member Elemeno Posted October 2, 2022 Advanced Member Report Share Posted October 2, 2022 22 minutes ago, Refin_ken said: after the calculation AmbientOcculions, the entire object turned black The calculation was very long, as if I use 16x anti-aliasing, after the calculation everything became black ill quickly put together something and see if i get same results my side Quote Link to comment Share on other sites More sharing options...
Member Refin_ken Posted October 2, 2022 Author Member Report Share Posted October 2, 2022 2 minutes ago, Elemeno said: ill quickly put together something and see if i get same results my side it happened only with this model, I have a different texture today, and there was no such thing Quote Link to comment Share on other sites More sharing options...
Advanced Member Elemeno Posted October 2, 2022 Advanced Member Report Share Posted October 2, 2022 mines baking fine.. 1 Quote Link to comment Share on other sites More sharing options...
Member Solution Refin_ken Posted October 2, 2022 Author Member Solution Report Share Posted October 2, 2022 Okay, the topic can be closed. I forgot to include triangulation 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 2, 2022 Report Share Posted October 2, 2022 At which step do you apply triangulation ? Could you share before and after process ? may be adding a pop-up warning should help users to avoid similar issue.. Quote Link to comment Share on other sites More sharing options...
Member Refin_ken Posted October 2, 2022 Author Member Report Share Posted October 2, 2022 1 hour ago, Carlosan said: At which step do you apply triangulation ? Could you share before and after process ? may be adding a pop-up warning should help users to avoid similar issue.. I don't know much about theory, but the only thing I noticed is that triangulation is always needed. I don't even know what it does, but if it is turned off, there are always some artifacts with the model. 1 Quote Link to comment Share on other sites More sharing options...
