  • 0
[Bug] Is Symmetry supported when using Shift with the Cut Off Tool in the Sculpt workspace?
tiburbage
Question
I'm finding that Shift works just fine to invert what gets removed when you are using a Lasso stroke with the Cut Off tool with Symmetry OFF, but with it ON, everything on the layer gets deleted.
If that should work, let me know if you can reproduce. If yes, let me know how I will report it if you want. If it works for you, I'd like to try to figure out what other setting is causing my attempts to fail.
2 answers to this question
  • 0
Well, whether bug or not, you can perform the operation with Symmetry OFF, then turn it back on, then mirror across the symmetry plane...
  • 0
Thanks for point it up.
Yes, you can report it at support@3dcoat.com
Answer this question...
