Member Kryslin Posted October 13, 2022 Member Report Share Posted October 13, 2022 I've come across something strange in 2022.48 (in fact, in the 2022 series): When using the stamp brush to place details on a mesh, with Symmetry enabled on the X axis, It sometimes does not place the details on one side. I've noticed that as the surface you're stamping on approaches vertical, the chance increases. Steps to repeat: 1) Create a cube, centered on the origin, and take it into the paint room. 2) Enable symmetry across the X axis, chose a brush alpha, and stamp mode. 3) Most of the stamps should appear across the x axis, but not all. Also, varying the size can cause symmetry to fail as well - usually smaller. This doesn't happen in 4.9.65 (which is the most recent version I could get working; 2021 wants to crash). If someone could verify this and let the devs know, or knows a workaround/fix for it, I'd appreciate it. 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 13, 2022 Report Share Posted October 13, 2022 Hi Bug reported, thanks for point it up. As workaround you can use Stamp drag mode Quote Link to comment Share on other sites More sharing options...
Member Kryslin Posted October 13, 2022 Author Member Report Share Posted October 13, 2022 Ok, so it was a bug. Excellent. Thanks for the reply. Will try the work around, too. 1 Quote Link to comment Share on other sites More sharing options...
Member Kryslin Posted November 12, 2022 Author Member Report Share Posted November 12, 2022 Just updated to 2022.49, and sadly, this bug is still there. 1) Start a new project, paint UV mapped mesh. 2) Load Cube 3) Enable X axis Symmetry (either X Mirror, or Radial Mirror). 4)Choose the Stamp Brush, choose an alpha, and begin to paint. 5)Bug should present itself. Tends to happen at smaller sizes and angles. Does not happen in all instances. It's almost like 3DCoat is losing the symmetry across the X-Axis. This happens with X/Y/Z Mirror and Radial Mirror. The work around of using the stamp drag brush works fine so long as the size of the alpha remains constant, and it doesn't have to change orientation on the mesh. It also gets flaky about orientation when you snap to a vertex. 1 Quote Link to comment Share on other sites More sharing options...
Member Kryslin Posted December 3, 2022 Author Member Report Share Posted December 3, 2022 Again, updated version to 2022.53, problem presents itself on provided models (Cube, Sphere, Torus) and an Imported, symmetric model, all Axis (X, Y, Z). Steps to reproduce are the same. 1 1 Quote Link to comment Share on other sites More sharing options...
Member Kryslin Posted December 15, 2022 Author Member Report Share Posted December 15, 2022 And here we go again... After re-downloading 2022.54 after the updater ate the executable, and re-installing... Bug is still there, using the aforementioned steps to reproduce, across all forms of symmetry, using multiple brushes of varying resolutions. On the off chance it might be me, Are there any particular version driver versions known to cause issues? I'm running an nVidia RTX3060, Studio Drivers 517.40, under Windows 10 Pro 21H2 19044.2251, on an i7-960 3.2ghz w/ 24GB ram (which tests good). DirectX runtime is 12.0, feature level 12_1. OpenGL is 4.6.0. I've been having issues after trying to update to newer nVidia drivers, because they're not recognizing the second monitor properly on installation on version past 517.40. 1 Quote Link to comment Share on other sites More sharing options...
Member Kryslin Posted February 2 Author Member Report Share Posted February 2 Pretty much a repeat of the last couple of posts. Problem persists in 2022.58. Managed to update drivers to current studio drivers. (Had to update the BIOS in my monitor. *****?) Same methods to generate. And it's only the stamp brush in the paint room. 2 Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted February 7 Report Share Posted February 7 Thanks for the long, long patience, fixed in 60. Quote Link to comment Share on other sites More sharing options...
Member Kryslin Posted March 19 Author Member Report Share Posted March 19 You're welcome. And yes, it is verified fixed. Thank you. 1 Quote Link to comment Share on other sites More sharing options...
