Member riuthamus Posted November 19, 2022 Member Share Posted November 19, 2022 So, recently I got a new Huion 4k display and got it all set up. When I moved my 3DCoat over to the display, all was good. However, upon closing the program and opening it again it just sits on a white screen and times out. I have to force the program shut and then, it won't work at all until I delete the folder. Once the folder is deleted it loads up on my ULTRAWIDE monitor (that is not 4k) and I have no issues. I can replicate this every time. Quote Link to comment Share on other sites More sharing options...
Solution Carlosan Posted November 20, 2022 Solution Share Posted November 20, 2022 Is this thread related to your issue ? It help to solve it ? Quote Link to comment Share on other sites More sharing options...
Member riuthamus Posted November 23, 2022 Author Member Share Posted November 23, 2022 (edited) It sounds like the same issue, but that driver has nothing to do with my setup. I do not have the same things he does. I will, however, find the audio driver and attempt to turn it off and back on and see if that has any change/effect. **EDIT** - That somehow worked. I am not using a Cintiq, however, I am using a HUION and when I turned off the audio driver and started the program I had no issues. Why that works/fixed it... I do not know but seems good for now. Let's hope this does not affect my streaming :P Edited November 23, 2022 by riuthamus 1 Quote Link to comment Share on other sites More sharing options...
