Member jammer42777 Posted November 30, 2022 Member Report Share Posted November 30, 2022 is there a way to load custom curves in the E Panel as shapes? Is there a way to load vector files as custom shapes? also is in the transform tool, is there a way to snap the gizmo to the voxel object that I have selected? Quote Link to comment Share on other sites More sharing options...
Solution Carlosan Posted November 30, 2022 Solution Report Share Posted November 30, 2022 E Panel curves are hard codec. To load custom curves you can Load Curves on Curves Tree. Quote Link to comment Share on other sites More sharing options...
Member jammer42777 Posted November 30, 2022 Author Member Report Share Posted November 30, 2022 Thank you!!! is there a tutorial available for the changing the gizmo for the transform tool? I have symmetry on the x axis, I want to move the plates into the armor on each side, but the pivot point is stuck in the center and I cannot move bot in or out uniformly. Or is there a workaround? I apologize for asking such beginner questions, but I really enjoy using 3dcoat and want to stick with it. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted November 30, 2022 Report Share Posted November 30, 2022 try pose tool Quote Link to comment Share on other sites More sharing options...
Member jammer42777 Posted December 1, 2022 Author Member Report Share Posted December 1, 2022 thank you that kind of worked bit there are all kinds of aliasing. Thank you for trying I might try something in the paint room as these are meant to be armored plating, maybe the extrude tool can work? I Quote Link to comment Share on other sites More sharing options...
Member jammer42777 Posted December 1, 2022 Author Member Report Share Posted December 1, 2022 so i tried re doing this place in surface mode using the extrude tool, it worked very well. I will be researching UVs and retopo. Thank you for your help! I have a lot to learn. Thank you so much for support! 1 Quote Link to comment Share on other sites More sharing options...
