symmetry behaves differently in surface mode, is this normal?
jammer42777
so  i am trying to split up an object,  I prefer using surface mode as opposed to voxel mode,  however in this case Instead of having the arms on one layer that I can symmetrically edit, it creates each arm as a new object.  is there a way to split the arms, but keep them both as one object in surface mode.
Your help is critical
You can Merge both using RMB over the layer to see Merge commands
Awesome!   I'll try that,  question  are there any tutorials that you would recommend for 3dcoat noobs?
Also do you have something like a patreon?
I would be happy to pay a small sum for help.
Thank you!
--Joshua
  • 2 weeks later...
