Advanced Member micro26 Posted January 3 Advanced Member Report Share Posted January 3 Hi all and happy new year! I wanted to make a script that does a task automatic. The task i want is switch to ao and curvarture layer respectivly and bake them. Currently there is no option to use the ambient occlusion (or curvarture) layer created so i was hoping if i could make a script . Thank you for your time. 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 12 Report Share Posted January 12 Hi, as you can see baked maps are saved on temp directory using random prefix. Quote Link to comment Share on other sites More sharing options...
Advanced Member micro26 Posted January 19 Author Advanced Member Report Share Posted January 19 Hi Carlosan, Thank you for your reply, i often texture the high poly model so no texture created yet. So i switch layers every time i want to refresh ao and curv layers to the newly sculpting operations. Hope it makes sense to add that option to the list of layer target. Also i was curious if there was some reference for a similar script. 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 20 Report Share Posted January 20 Currently there is no option to use the ambient occlusion (or curvarture) layer created Into the current layer (AO layer created previously) it is not helpful ? Quote Link to comment Share on other sites More sharing options...
