Member NLPLP Posted January 14, 2023 Member Report Share Posted January 14, 2023 When moving vertices with the select tool (using move select mode), the snapping to surrounding vertices is very inconsistent and in most cases, many tries at multiple angles are needed. Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted January 14, 2023 Report Share Posted January 14, 2023 19 minutes ago, NLPLP said: When moving vertices with the select tool (using move select mode), the snapping to surrounding vertices is very inconsistent and in most cases, many tries at multiple angles are needed. After selecting the vertices, switch to the Select/Transform tool, this will give you control over the move Quote Link to comment Share on other sites More sharing options...
Member NLPLP Posted January 14, 2023 Author Member Report Share Posted January 14, 2023 4 hours ago, Oleg_Shapo said: After selecting the vertices, switch to the Select/Transform tool, this will give you control over the move All Im trying to do is to snap/weld the vertices together. Yes the Select /Transform always highlight the vert nearby but it doesnt snap. Is there something Im missing? Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted January 15, 2023 Report Share Posted January 15, 2023 14 hours ago, NLPLP said: snap/weld the vertices together Either we are talking about this tool, or I do not understand what you mean. Quote Link to comment Share on other sites More sharing options...
Member NLPLP Posted January 16, 2023 Author Member Report Share Posted January 16, 2023 On 1/15/2023 at 6:22 AM, Oleg_Shapo said: Either we are talking about this tool, or I do not understand what you mean. Oleg This tool is more of a global option. I want to be able to select a vert or a number of vertices and have them snap/weld to other vertices when I move them(with the move tool or brush tool) within a prescribed tolerance. Quote Link to comment Share on other sites More sharing options...
Member NLPLP Posted January 16, 2023 Author Member Report Share Posted January 16, 2023 (edited) On 1/15/2023 at 6:22 AM, Oleg_Shapo said: Either we are talking about this tool, or I do not understand what you mean. Oleg Here s a video of the snapping/merge functionality that Im looking for. Its fairly standard on most modeling apps this is from Blender. Blender 2023-01-16 09-29-38.mp4 Edited January 16, 2023 by NLPLP Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted January 16, 2023 Report Share Posted January 16, 2023 You can do the same as in Blender with the Add/Split tool + RMB Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted January 16, 2023 Report Share Posted January 16, 2023 Quote Link to comment Share on other sites More sharing options...
Member NLPLP Posted January 16, 2023 Author Member Report Share Posted January 16, 2023 1 hour ago, Oleg_Shapo said: Oleg Yes I tried this (as well as doing the same using the select tool) and its highly inconsistent. It only works 20% of the time on the 2022.57 build Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted January 16, 2023 Report Share Posted January 16, 2023 Please send the scene and specify which dots need to be connected. I will test. Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted January 16, 2023 Report Share Posted January 16, 2023 Yes, I forgot. Sometimes it helps to increase the radius of the pen for capture. That is, it should not be too small. Quote Link to comment Share on other sites More sharing options...
Member MJonathan Posted January 17, 2023 Member Report Share Posted January 17, 2023 (edited) Yes, I tried the same with Add/Split Tool RMB, with different radius, and sometimes it woks perfect at first, but other occasions I need to move the perspective camera to snap the vertex. Edited January 17, 2023 by MJonathan Quote Link to comment Share on other sites More sharing options...
Member NLPLP Posted January 17, 2023 Author Member Report Share Posted January 17, 2023 8 hours ago, Oleg_Shapo said: Please send the scene and specify which dots need to be connected. I will test. Oleg I restarted 3D Coat and now works as you said. I really love the double functionality of the tool as it lets you create new polys and split existing ones. As a side request for this tool, could you maybe add the functionality of adding a gizmo so that we know where in 3D space we added the point and translate it accordingly ? Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted January 17, 2023 Report Share Posted January 17, 2023 6 hours ago, NLPLP said: As a side request for this tool, could you maybe add the functionality of adding a gizmo so that we know where in 3D space we added the point and translate it accordingly ? While I can advise you to use the ZX... hotkey combination to move the point (s) in the plane. Or hotkeys x, y or z to move along the axes Quote Link to comment Share on other sites More sharing options...
Member NLPLP Posted January 17, 2023 Author Member Report Share Posted January 17, 2023 4 hours ago, Oleg_Shapo said: While I can advise you to use the ZX... hotkey combination to move the point (s) in the plane. Or hotkeys x, y or z to move along the axes Thanks Oleg Thank you. I tried it and while the functionality seems to be there , it just seems waaaaay too clicky. The tool is really awesome as it also helps you layout polys and slice them .... it just becomes cumbersome when you have to perform all these keystrokes to get them where you want I think it would be a much more intuitive option if some gizmo functionality was there. I appreciate all your help and looking forward to help improve this awesome software 1 Quote Link to comment Share on other sites More sharing options...
