Advanced Member phoenixart Posted January 21, 2023 Advanced Member Report Share Posted January 21, 2023 (edited) I recently did a fresh install of 3D Coat on a new PC, and I'm noticing something strange with the Extruder brush. When I extrude, I get this weird protrusion from the surface. So, instead of the extrusion being one thing with the surface, I get this detached area along the edges: https://freeimage.host/i/HchsrPV Perhaps I had tweaked the settings on the old PC, but can't figure out what settings it is causing this. I thought it could be the falloff, but even at 100% I still get similar results. Any idea? Edited January 21, 2023 by phoenixart 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 21, 2023 Report Share Posted January 21, 2023 Are you meaning Clay engine > extruder on Voxel mode ? RMB > Restore Default it is not helpful ? Try turning on use current alpha Quote Link to comment Share on other sites More sharing options...
Advanced Member phoenixart Posted January 21, 2023 Author Advanced Member Report Share Posted January 21, 2023 Thanks, @Carlosan I have use current alpha on, in fact, the alpha is working fine. The problem is with the edge of the alpha map, where there's distance between the brushed area, and the voxel surface. Where do I find the option Clay Engine > extruder on Voxel mode? I searched through the main menus, and in the preferences, but I couldn't find it. By the way, these are the settings I'm using with the Extruder brush, which is in stamp mode. https://freeimage.host/i/Hc6XAMv Quote Link to comment Share on other sites More sharing options...
Advanced Member phoenixart Posted January 21, 2023 Author Advanced Member Report Share Posted January 21, 2023 Hm... it seems it's a bug. It works with the other brush mode, like radius, depth, vertex curve, curve, but when I switch to stamp than the issue shows up. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 21, 2023 Report Share Posted January 21, 2023 ahhhh... stamp It is working fine from my side. Do you have any stencil active ? Quote Link to comment Share on other sites More sharing options...
Reputable Contributor Solution Fluffy Posted January 21, 2023 Reputable Contributor Solution Report Share Posted January 21, 2023 3 hours ago, phoenixart said: Hm... it seems it's a bug. It works with the other brush mode, like radius, depth, vertex curve, curve, but when I switch to stamp than the issue shows up. It seems like using the Stamp tool at really large sizes on a curved surface can lead to protruding edges if the projected edge of the brush alpha falls too far from the surface you're applying it to. In order to avoid disconnected/protruding edges try swapping the Pick Trajectory setting to Pick Average Vertex Position and setting the Position Sampling value to 200%. 2 Quote Link to comment Share on other sites More sharing options...
Advanced Member phoenixart Posted January 22, 2023 Author Advanced Member Report Share Posted January 22, 2023 Thanks @Fluffy! That worked. I had tried the average vertex position, but without changing the sampling. Thanks for pointing that out! Quote Link to comment Share on other sites More sharing options...
