  • 0
Problem with UV set in Paint room
Stefka
Question
Dear Forum.
I´m new in 3DCoat and just working for about a month with the software.
I create my model with Sketchup 2017.
System: Laptop, 8GB, 2.9 GHz, Windows 10 Home
3DCoat, Ver. 2022.57
I use 3DCoat for texturing, right now. Generating the UV set on loading, out of the Sketchup model, than painting in the paint room. Model is imported as OBJ (even so, to solve my problem, I also tried to import as Collada or FBX file) with "Paint UV mapped mesh".
My first model worked out fine and there where no problems. The model had about 80k triangles.
In UV room I`m working on the UV set, adding and deleting seams, everything works fine.
Unwrapping, result is fine in UV room.
Return to paint room, the UV Set is broken.
There are multiple seam lines going from all over the UV set to the upper left corner.
I`don´t think that the problem comes from the model itself. The model consists of 4 separate models. I already painted each of them separately and it worked fine. For some spezial reason I need one texture map and because I`m not familiar with baking and working with separate texture maps in 3DCoat, I made a new model including all the separate models in one file.
I would highly appreciate if anybody can give me a hint where the problem comes from.
Thank you
Walter
17 answers to this question
  • 0
Hi
After unwrapping, try before switch to paint room to Apply UV-set
Hope this help
  • 0
Dear Carlosan
Thank you for your answer, but sorry this does not help. :-(
Any other idea?
Your assistance is highly appreciated.
  • 0
2 hours ago, Stefka said:
Dear Carlosan
Any other idea?
i would like to say there's a fix ... but .. the uv auto unwrap doesn't always work perfectly .. and like anything automatic ... manual is always better ... doesn't have to be perfect but seam it out and get a better uv, you'll find the bakes are better quality too
  • 0
Dear Elemeno
Thank you for your answer.
First step is automated unwrapping, than I do the manual rework in UV room, unwrapping and everything looks fine. After return to paint room the problem occurs.
So I don´t think it has anything to do with the automated process of UV unwrapping. There must be anything else.
I thought thay anyone may have had this problem already and found a solution for it.
But anyway thanks for your assistance.
Best regards
  • 0
Hi Carlosan
I like to send you the model by PN. How can I do it? In your profile I found a note button, but I´m not allowed to send a message.
Don´t want to share it public.
Thank you
Walter
  • 0
Hi Carlosan
I never used discord. I got an account now. But how can I contact you? The system requests a 4 digit Tag ID to add you as a friend to communicate with you.
Can you provide it to me?
Sorry for the inconveniences.
  • 0
I appreciate your help, but can´t get on to contact you by discord.
Don´t know what your last message means. There is no relevant informations when I RMB over your name / Logo in 3DCoat forum.
Tried to find "Carlosan" in discord search function, no result
Tried to find in "discordhub.com" to find your name, no result.
So maybe I´m not able to contact you. Very sorry.
Just in case you can afford some more time, please let me know the right way.
Thank you.
  • 0
First you need to post something to be able to Dm.
  • 0
I opened the model in version 2022.60 It is triangulated and has no N-Gons.
After redoing the UVs on UV room
Clear Seams > Sharp Seams
I switched back to Paint room, I press NO to the warning message
Everything looks ok
Please open his project, hope this help
OilTank.zip
  • 0
Thank you very much.
Your edited project works fine.
Following your workflow with my exact same project I get the same issues even though I upgraded to the .60 version.
Very strange to me.
But I can still work. Thanks very much!
Answer this question...
