  • 0
Texture missing from Blender FBX when imported into 3D Coat
michaelws
Question
I have an unwrapped sphere crudely painted in Blender.  I export as an FBX with "Selected Object" checked.  I import into 3D Coat for Per Pixel painting and the object comes in but no painting.  I would like to be able to go back and forth between the two programs but it will be impossible if the texture doesn't come through from Blender.
I am using Blender ver. 3.4.1 and 3D Coat 2022.57
Thanks for any suggestions.
9 answers to this question
  • 0
Do you had save the painted image to texture image before export it ?
  • 0
strange, fbx import link textures automatically.
Try importing it using this command
Or use Blender applink to bridge both apps.
  • 0
That helped a little bit.  My object is unwrapped in Blender with UDIMS.  When I follow your example above it brings in only 1 of the 2 UDIM maps
UDIMs_3DCoat.thumb.jpg.642566da4c00c505d2b2e4e34f37657e.jpgSavedUDIM_PNGs.jpg.d3b49a535f5297cbe4235dfcddd2ed59.jpg1882733878_UDIMSBlender.thumb.jpg.055f98d7fb7f1a378cd7abb043fc8035.jpg
  • 0
Every time  I open 3D Coat I get this panel with the header "App link update required."
The 3D Coat applink addon appears to be the latest version installed in Blender.  It does send over the selected objects (but without any textures).
In that box it says that if this message pops up again and again then 3D Coat is unable to copy the App Link files and instructs me to do this manually.  I cannot locate, on my Windows 11, where "Coatinstallpath/data/ToolsPresets/InstallAppLinks/Blender/files" is located, nor where the location to copy it to is located, "BlenderInstallPath/scripts/addons/io_coats3d/"
Can you help me with this?
Sorry to be such a bother Carlosan.  I appreciate your continued help.
  • 0
Try running 3DC as administrator
All tips related to applink installation are here
Answer this question...
