Paint objects disappear, appear dark and transparent
PixelDust
I have retopologized and baked my objects individually. Name correspendence is on. I can paint on one object at a time and export the maps, but the next time I open the file, only one object seems to display correctly in the Paint room. All the others are dark and transparent. Also, my paint objects keep disappearing. For example, I can paint an object and export it. I save the file and exit 3D-Coat. Next time I reopen the same file, the paint object I exported isn't there anymore.
Everything looks fine in the Retopo room.
In the screenshot here, all paint objects and surface materials are visible. I turned off "Show voxels in paint room".
I can't tell where I am going wrong. The file is too large to share here.
I'm getting frustrated. Can someone help? Thank you!
You are not painting Layer0, right ?
This model have uDims ?
Nope, not painting layer 0, and no UDIMs. There are separate UV maps for each retopo object. I am getting duplicate UV maps somehow after baking. It might be because I've had to bake again because the paint objects get screwed up. Thanks!
you welcome
this bug was fixed time ago
Are you using latest version 2023.7 ?
I am now. I was using 2023.6 before.
One more question: What's the best way to export one object and its textures from the paint room at a time? When I click "Export Objects and Textures" from the file menu, it will export the objects and textures for all my objects, even the ones that are hidden, and it overwrites what I had saved before.
Thank you!
Edited by PixelDust
Textures > Export is the only way currently
