Member PixelDust Posted March 17, 2023 Member Report Share Posted March 17, 2023 I have retopologized and baked my objects individually. Name correspendence is on. I can paint on one object at a time and export the maps, but the next time I open the file, only one object seems to display correctly in the Paint room. All the others are dark and transparent. Also, my paint objects keep disappearing. For example, I can paint an object and export it. I save the file and exit 3D-Coat. Next time I reopen the same file, the paint object I exported isn't there anymore. Everything looks fine in the Retopo room. In the screenshot here, all paint objects and surface materials are visible. I turned off "Show voxels in paint room". I can't tell where I am going wrong. The file is too large to share here. I'm getting frustrated. Can someone help? Thank you! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 17, 2023 Report Share Posted March 17, 2023 You are not painting Layer0, right ? This model have uDims ? Quote Link to comment Share on other sites More sharing options...
Member PixelDust Posted March 17, 2023 Author Member Report Share Posted March 17, 2023 Nope, not painting layer 0, and no UDIMs. There are separate UV maps for each retopo object. I am getting duplicate UV maps somehow after baking. It might be because I've had to bake again because the paint objects get screwed up. Thanks! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 17, 2023 Report Share Posted March 17, 2023 you welcome this bug was fixed time ago Are you using latest version 2023.7 ? Quote Link to comment Share on other sites More sharing options...
Member PixelDust Posted March 17, 2023 Author Member Report Share Posted March 17, 2023 (edited) I am now. I was using 2023.6 before. One more question: What's the best way to export one object and its textures from the paint room at a time? When I click "Export Objects and Textures" from the file menu, it will export the objects and textures for all my objects, even the ones that are hidden, and it overwrites what I had saved before. Thank you! Edited March 17, 2023 by PixelDust Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 17, 2023 Report Share Posted March 17, 2023 Textures > Export is the only way currently 1 Quote Link to comment Share on other sites More sharing options...
Member PixelDust Posted March 18, 2023 Author Member Report Share Posted March 18, 2023 Thanks, Carlosan! Much appreciated! 1 Quote Link to comment Share on other sites More sharing options...
