Member awhawkins Posted March 30, 2023 Member Share Posted March 30, 2023 I am a blender and former zBrush user who is considering purchasing 3dcoat. I like to create base meshes using primitaves like Shane Olson. I have been creating my basemeshes in Blender similar to the one below where each part is in it own layer until it is time to merge and sculpt in the details. As I am learning 3dcoat, I have not figured out a way to create each part on its own layer to manipulate that shape without changing the other layers as I do in Blender. Can someone explain how to do this or point me in the right direction? Also, can someone recommend some tutorials for newbies for this software? Quote Link to comment https://3dcoat.com/forum/index.php?/topic/28159-blockout/ Share on other sites More sharing options...
Advanced Member Koray Posted March 30, 2023 Advanced Member Share Posted March 30, 2023 (edited) So you want us to believe that; you figured out Blender, you figured out Zbrush but you couldnt figure out 3DCoat? I thought I've seen it all Edited March 30, 2023 by Koray Quote Link to comment https://3dcoat.com/forum/index.php?/topic/28159-blockout/#findComment-187611 Share on other sites More sharing options...
Carlosan Posted March 30, 2023 Share Posted March 30, 2023 Hi This video offers a quick tip about manipulating individual parts of a VoxTree layer (in the Sculpt Workspace) or separating them into separate child layers Quote Link to comment https://3dcoat.com/forum/index.php?/topic/28159-blockout/#findComment-187619 Share on other sites More sharing options...
Member awhawkins Posted March 31, 2023 Author Member Share Posted March 31, 2023 19 hours ago, Koray said: So you want us to believe that; you figured out Blender, you figured out Zbrush but you couldnt figure out 3DCoat? I thought I've seen it all Koray, I don't want you to believe anything. What I would like for you to understand is that I am a Blender user and former zBrush user who is considering purchasing 3dcoat. I am looking for information how to accomplish a certain task in 3dcoat. And since you believe you have seen it all perhaps you can provide some information how to accomplish this partucular task in this software. 1 Quote Link to comment https://3dcoat.com/forum/index.php?/topic/28159-blockout/#findComment-187648 Share on other sites More sharing options...
Member awhawkins Posted March 31, 2023 Author Member Share Posted March 31, 2023 16 hours ago, Carlosan said: Hi This video offers a quick tip about manipulating individual parts of a VoxTree layer (in the Sculpt Workspace) or separating them into separate child layers Carlosan, Thank you for the information. I will check out this video. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/28159-blockout/#findComment-187649 Share on other sites More sharing options...
Advanced Member Koray Posted March 31, 2023 Advanced Member Share Posted March 31, 2023 (edited) Off topic- I've probably seen all the base meshes out there too. The hardest thing for me is to learn anatomy so I need and use some Edited March 31, 2023 by Koray Quote Link to comment https://3dcoat.com/forum/index.php?/topic/28159-blockout/#findComment-187651 Share on other sites More sharing options...
Contributor poeboi Posted March 31, 2023 Contributor Share Posted March 31, 2023 (edited) This post was recognized by Carlosan! poeboi was awarded the badge 'Great Content' and 1 points. On 3/30/2023 at 2:04 AM, awhawkins said: I am a blender and former zBrush user who is considering purchasing 3dcoat. I like to create base meshes using primitaves like Shane Olson. I have been creating my basemeshes in Blender similar to the one below where each part is in it own layer until it is time to merge and sculpt in the details. As I am learning 3dcoat, I have not figured out a way to create each part on its own layer to manipulate that shape without changing the other layers as I do in Blender. Can someone explain how to do this or point me in the right direction? Also, can someone recommend some tutorials for newbies for this software? The workflow where in you, segment a larger mesh into smaller meshes, and modify each to make the larger look good is pretty straight forward but a lot of the "good stuff" and "good to knows" is a bit hidden away Here are some things worth looking into and being aware of1. the tools "copy", "cut & clone", "split by curve", "split" and other tools for splitting objects These are tools that allow you to segment the bigger piece into smaller, child pieces pretty accurately. Be also aware how a child layer works. By default, imports and copy etc selects the same layer you are standing on in surface tree, what you want to make sure when using these tools is that you are on a child layer. To make a child layer, hover over layer in tree, to see the little [+]. pressing + produces child layer, set it to active before doing something like "apply" or "import" when cut and clone-ing, or separating. It's to make sure it is truly separate, and not just floating piece on same layer. Split by curve is essentially, you draw a closed curve over the object, rmb on the curve and "split by curve". You can then even have some beveled gap between these. Allows for precise splitting. Also nice to be aware of the RMB on sculpt tree object options, such as "subtract from" ... "merge visible" ... "copy and merge to" for in the very least, Vox Mode, you can do these types of operations infinite amount of times and they simply work. Usecases: removing the volume of one object from another, without destroying either. Merging all visible as a copy on it's own layer. Copying something on a layer and merging it to (boolean) another layer, to compound detail. (also happens to be aware of resolution here. Layer you merge from will accommodate layer you merge to. Merging 300k tris into 1 million tris, suddenly you can end up with very dense target mesh)2. Knowing your resolution To quickly adjust resolutions in Vox mode , please use the RMB on object in sculpt tree and use the "resampling" option. You can then make the mesh % denser or less dense. Set the sampling preset to good or smooth for best results. It is tempting to use the "resolution 2x" but these actually make your mesh physically smaller or bigger. Proxy and multires is more for surface mode and only when you need to step up or down. I find anecdotally, that when blocking things out, a pretty OK resolution is ballpark 300_000 tris. At this level, freezing is easy to smooth, viewport is fast, mesh is a whole lot more maleable when using Move tool, et cetera. When you need more detail, jump to millions.2.5 Why does my vox mesh detail look chunky like lots of small boxes as opposed to surface, you cannot circumvent a lot of localized resolution or detail without splitting the mesh. Because it is more like a painting, just even px grid of details. very typical phenomenon for example is if you have a character, the face parts like eyes; eyelids; mouth; etc will look chunky and not crisp without a lot of vox resolution. Trial and error is in order to figure this out but, you might be shocked at first when taking your 1 million tris character sculpt and trying to turn it into Vox, the entire face just melts. It is better to separate the face and keep face as some million tris in vox mode to preserve it's detail, while body / the rest which does not require as much to contain it's detail has more reasonable amount of tris.3. Quick Pick I have this set to hotkey H. Very handy when switching between pieces. You can hover mouse over a object in viewport, press (I press H) the hotkey and you make that sculpt object active in the tree.4. Vox Hide (or in general, hide surface to create surface) When you hide stuff in general in 3DCoat, you almost always have the option of taking what's hidden and separating it out into it's own mesh in some way. Examples: Surface mode: you can freeze a surface (or paint parts of a surface on a layer, and select opaque pixels to get freeze mask) -> hide frozen faces (I believe in freeze title bar menu) -> separate hidden faces (I believe geometry title bar menu) and you will have separated just that surface part. Vox mode: is where it gets good because, you can use the "Vox Hide" tool to hide big chunks of your models with thickness, and you can then use the "Hidden to geometry" options to get only what you hid, as a new occurrence of Vox object.5. Gizmoless transforms these are the tools that allow you to re-orient and manipulate your sculpt object in screen space and viewport, with only hotkey presses and drag as opposed to explicitly using the Transform tool and manipulating it via GIzmo. I cannot stress enough what a relief it is to be able to use these together with Quick Pick for quickly moving and getting together your separated pieces. ...There's lots of stuff,. This is not meant to deter you from seeking tutorials or help, but anecdotally in 3DCoat the effort is best spent thinking "how can I accomplish X" and then examining the various tools, and experimenting with them, see where they can get you. Trying to follow a tutorial 1:1 it can get you ways there but, personally I find it's better to just experiment. Sitting and waiting on tutorials because "that's when I can finally start using the software and equip myself how to use it" you might be waiting forever. Best of luckEdit: since you mention being acquainted with Blender. I therefore highly recommend you get acquainted with the Blender applink, because it might be good to for example try some things with 3dcoat and sending it to Blender, versus trying to do everything in 3DCoat at first. Some use and some getting acquainted with it is better than nothing. You might for example, like how quickly you can work with basemeshes in 3DCoat and send to Blender for sculpting, etc. or sending back to 3DCoat for UVing, adding some detail. They're very good softwares to use together Edited March 31, 2023 by poeboi 1 Quote Link to comment https://3dcoat.com/forum/index.php?/topic/28159-blockout/#findComment-187654 Share on other sites More sharing options...
Advanced Member animk Posted March 31, 2023 Advanced Member Share Posted March 31, 2023 This post was recognized by Carlosan! animk was awarded the badge 'Helpful' and 1 points. On 3/29/2023 at 5:04 PM, awhawkins said: I am a blender and former zBrush user who is considering purchasing 3dcoat. I like to create base meshes using primitaves like Shane Olson. I have been creating my basemeshes in Blender similar to the one below where each part is in it own layer until it is time to merge and sculpt in the details. As I am learning 3dcoat, I have not figured out a way to create each part on its own layer to manipulate that shape without changing the other layers as I do in Blender. Can someone explain how to do this or point me in the right direction? Also, can someone recommend some tutorials for newbies for this software? I guess you have "auto pick" on? On the very top of the tool bar. If you have have it on, you will automatically switch to another layer when you touch those mesh in that layer. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/28159-blockout/#findComment-187655 Share on other sites More sharing options...
Member awhawkins Posted April 2, 2023 Author Member Share Posted April 2, 2023 On 3/31/2023 at 2:59 AM, poeboi said: The workflow where in you, segment a larger mesh into smaller meshes, and modify each to make the larger look good is pretty straight forward but a lot of the "good stuff" and "good to knows" is a bit hidden away Here are some things worth looking into and being aware of1. the tools "copy", "cut & clone", "split by curve", "split" and other tools for splitting objects These are tools that allow you to segment the bigger piece into smaller, child pieces pretty accurately. Be also aware how a child layer works. By default, imports and copy etc selects the same layer you are standing on in surface tree, what you want to make sure when using these tools is that you are on a child layer. To make a child layer, hover over layer in tree, to see the little [+]. pressing + produces child layer, set it to active before doing something like "apply" or "import" when cut and clone-ing, or separating. It's to make sure it is truly separate, and not just floating piece on same layer. Split by curve is essentially, you draw a closed curve over the object, rmb on the curve and "split by curve". You can then even have some beveled gap between these. Allows for precise splitting. Also nice to be aware of the RMB on sculpt tree object options, such as "subtract from" ... "merge visible" ... "copy and merge to" for in the very least, Vox Mode, you can do these types of operations infinite amount of times and they simply work. Usecases: removing the volume of one object from another, without destroying either. Merging all visible as a copy on it's own layer. Copying something on a layer and merging it to (boolean) another layer, to compound detail. (also happens to be aware of resolution here. Layer you merge from will accommodate layer you merge to. Merging 300k tris into 1 million tris, suddenly you can end up with very dense target mesh)2. Knowing your resolution To quickly adjust resolutions in Vox mode , please use the RMB on object in sculpt tree and use the "resampling" option. You can then make the mesh % denser or less dense. Set the sampling preset to good or smooth for best results. It is tempting to use the "resolution 2x" but these actually make your mesh physically smaller or bigger. Proxy and multires is more for surface mode and only when you need to step up or down. I find anecdotally, that when blocking things out, a pretty OK resolution is ballpark 300_000 tris. At this level, freezing is easy to smooth, viewport is fast, mesh is a whole lot more maleable when using Move tool, et cetera. When you need more detail, jump to millions.2.5 Why does my vox mesh detail look chunky like lots of small boxes as opposed to surface, you cannot circumvent a lot of localized resolution or detail without splitting the mesh. Because it is more like a painting, just even px grid of details. very typical phenomenon for example is if you have a character, the face parts like eyes; eyelids; mouth; etc will look chunky and not crisp without a lot of vox resolution. Trial and error is in order to figure this out but, you might be shocked at first when taking your 1 million tris character sculpt and trying to turn it into Vox, the entire face just melts. It is better to separate the face and keep face as some million tris in vox mode to preserve it's detail, while body / the rest which does not require as much to contain it's detail has more reasonable amount of tris.3. Quick Pick I have this set to hotkey H. Very handy when switching between pieces. You can hover mouse over a object in viewport, press (I press H) the hotkey and you make that sculpt object active in the tree.4. Vox Hide (or in general, hide surface to create surface) When you hide stuff in general in 3DCoat, you almost always have the option of taking what's hidden and separating it out into it's own mesh in some way. Examples: Surface mode: you can freeze a surface (or paint parts of a surface on a layer, and select opaque pixels to get freeze mask) -> hide frozen faces (I believe in freeze title bar menu) -> separate hidden faces (I believe geometry title bar menu) and you will have separated just that surface part. Vox mode: is where it gets good because, you can use the "Vox Hide" tool to hide big chunks of your models with thickness, and you can then use the "Hidden to geometry" options to get only what you hid, as a new occurrence of Vox object.5. Gizmoless transforms these are the tools that allow you to re-orient and manipulate your sculpt object in screen space and viewport, with only hotkey presses and drag as opposed to explicitly using the Transform tool and manipulating it via GIzmo. I cannot stress enough what a relief it is to be able to use these together with Quick Pick for quickly moving and getting together your separated pieces. ...There's lots of stuff,. This is not meant to deter you from seeking tutorials or help, but anecdotally in 3DCoat the effort is best spent thinking "how can I accomplish X" and then examining the various tools, and experimenting with them, see where they can get you. Trying to follow a tutorial 1:1 it can get you ways there but, personally I find it's better to just experiment. Sitting and waiting on tutorials because "that's when I can finally start using the software and equip myself how to use it" you might be waiting forever. Best of luckEdit: since you mention being acquainted with Blender. I therefore highly recommend you get acquainted with the Blender applink, because it might be good to for example try some things with 3dcoat and sending it to Blender, versus trying to do everything in 3DCoat at first. Some use and some getting acquainted with it is better than nothing. You might for example, like how quickly you can work with basemeshes in 3DCoat and send to Blender for sculpting, etc. or sending back to 3DCoat for UVing, adding some detail. They're very good softwares to use together Thanks Poeboi for your response. What I am trying to accomplish is the opposite. I want to add low poly primitives to a layer one at a time to manipulate individually without impacting the other layers. I will take a look at the applink in blender and see how this works. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/28159-blockout/#findComment-187708 Share on other sites More sharing options...
Advanced Member MJonathan Posted April 2, 2023 Advanced Member Share Posted April 2, 2023 25 minutes ago, awhawkins said: Thanks Poeboi for your response. What I am trying to accomplish is the opposite. I want to add low poly primitives to a layer one at a time to manipulate individually without impacting the other layers. I will take a look at the applink in blender and see how this works. Are you using Sculpt Tree to separate the geometry? Quote Link to comment https://3dcoat.com/forum/index.php?/topic/28159-blockout/#findComment-187709 Share on other sites More sharing options...
Member Hickz Posted April 2, 2023 Member Share Posted April 2, 2023 23 minutes ago, awhawkins said: Thanks Poeboi for your response. What I am trying to accomplish is the opposite. I want to add low poly primitives to a layer one at a time to manipulate individually without impacting the other layers. I will take a look at the applink in blender and see how this works. That’s where 3dcoat with its restrictive room separation is lacking, imo. The stuff with primitives is soooo much easier in Zbrush, where you’ve got quad topology, zremesher, all the sculpt tools available to work with on these low poly meshes. In 3dcoat you’d have to use the modeling room for that, where you can’t use almost all the tools from sculpt room and the workflow is clunky (retopo meshes and sculpt meshes are separate and can be accessed from either of 3 rooms: modeling/retopo, sculpt) Quote Link to comment https://3dcoat.com/forum/index.php?/topic/28159-blockout/#findComment-187710 Share on other sites More sharing options...
Advanced Member MJonathan Posted April 2, 2023 Advanced Member Share Posted April 2, 2023 This post was recognized by Carlosan! MJonathan was awarded the badge 'Helpful' and 1 points. I know the Shane Olson workflow, I was zbrush user, and you can replicate it on 3dCoat. 1 Quote Link to comment https://3dcoat.com/forum/index.php?/topic/28159-blockout/#findComment-187711 Share on other sites More sharing options...
Member awhawkins Posted April 3, 2023 Author Member Share Posted April 3, 2023 On 4/2/2023 at 11:58 AM, MJonathan said: Are you using Sculpt Tree to separate the geometry? MJonathan, I have used the sculpt tree in the sculpting room, however in the modeling room I have not gotten the same result without the mesh be joined to the other mesh.. How do you do this in the modeling room? And what brush are you using to add these spheres to the mesh? Quote Link to comment https://3dcoat.com/forum/index.php?/topic/28159-blockout/#findComment-187732 Share on other sites More sharing options...
Advanced Member MJonathan Posted April 4, 2023 Advanced Member Share Posted April 4, 2023 This post was recognized by Carlosan! MJonathan was awarded the badge 'Helpful' and 1 points. Sculpt Layers (Sculpt Room) and Polygroup Layers (Modeling Room) are not connected, I hope developers connect these rooms. My recommendation.. you need to use sculpt room for this workflow. The brush is Spheres, you can find it in Voxel Tools in the left panel. Or alternative use 3d primitive tool located in the left panel too. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/28159-blockout/#findComment-187736 Share on other sites More sharing options...
Member awhawkins Posted April 4, 2023 Author Member Share Posted April 4, 2023 19 hours ago, MJonathan said: Sculpt Layers (Sculpt Room) and Polygroup Layers (Modeling Room) are not connected, I hope developers connect these rooms. My recommendation.. you need to use sculpt room for this workflow. The brush is Spheres, you can find it in Voxel Tools in the left panel. Or alternative use 3d primitive tool located in the left panel too. Thanks MJonathan. I will try the spheres. I just made the jump and purchased 3dCoat. I don’t really see any books or good courses to get one started. Can you recommend any? Quote Link to comment https://3dcoat.com/forum/index.php?/topic/28159-blockout/#findComment-187758 Share on other sites More sharing options...
