  • 1
How to render Height info?? To make alphas or displacement maps. SOLVED :D
Koray
Question
I tried to create a depth render but couldnt figure out how. I rotated the object to show you there is something there.
You may also call it an alpha or a height map.
Is there a way to create a black and white render with height info in the render room?
Edited by Koray
renamed to height :)
3 answers to this question
  • 1
Carlosan
Koray was awarded the badge 'Helpful' and 1 points.
Tested it works. Notes to self if I forget since nobody else replied:
- File/Export/ Export Depth Along Y
- Make sure Y (top) is up
- Uncheck everything
- Patch size 100. Higher makes small, lower almost crashed 3dc
- Be aware even though I select tif, 3dc tries to export as exr. tif is 32bit still.
- Can go 16K, huge file size. Nice :)
- Important: Zb couldnt read 32bit tif, needed to convert to 16 bit in PS. Displaces nice.
- Exr export is a mess. Avoid for now. Havent tried other formats.
Edited by Koray
  • 0
Found the answer in the thread linked below. Old version info not tested if it still works yet:
Answer this question...
