Member muomuoaabb Posted April 19, 2023 Member Share Posted April 19, 2023 Im new to 3dcoat.Idont know if its a bug or just I didnt do the right way?I use freeze tool to make a mask area and then switch to move tool trying to modifiy mesh ,the mask area just turn to some rectangle and glitch?! if I change to some clay brush tool,the mask just disappear like never exsist.. Restart program or open a new blank file,the issue still remain.. Pretty sad cant use freeze tool like zbrush through Strange why I cant paste image,dont know how to use URL insert image,sorry Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted April 19, 2023 Share Posted April 19, 2023 1 hour ago, muomuoaabb said: Pretty sad cant use freeze tool like zbrush through In version 23.16 I freeze and move without problems. More steps are needed to repeat the mistake. Please submit a crash report via the feedback form. When a failure occurs, the program will prompt you to do so. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 19, 2023 Share Posted April 19, 2023 using latest v 2023.16 ? win or mac version ? are you working on surface or voxel mode ? Quote Link to comment Share on other sites More sharing options...
Member Solution Dionizio Posted September 19, 2024 Member Solution Share Posted September 19, 2024 This post was recognized by Carlosan! Dionizio was awarded the badge 'Helpful' and 1 points. On 4/19/2023 at 2:57 AM, muomuoaabb said: Im new to 3dcoat.Idont know if its a bug or just I didnt do the right way?I use freeze tool to make a mask area and then switch to move tool trying to modifiy mesh ,the mask area just turn to some rectangle and glitch?! if I change to some clay brush tool,the mask just disappear like never exsist.. Restart program or open a new blank file,the issue still remain.. Pretty sad cant use freeze tool like zbrush through Strange why I cant paste image,dont know how to use URL insert image,sorry i Dont know if it tooo late , but i believe the answer can help some body else . To make it work in voxel you need to turn off the "voxelize immediately" option in the "Tool option" Panel. With Surface sculpting is working nicely , no issues for me 2 Quote Link to comment Share on other sites More sharing options...
