New Member abontav Posted April 20, 2023 New Member Report Share Posted April 20, 2023 Hi all! i have a problem with the huion kamvas 13 and 3dcoat Linux(using version 2023.16, but happens in all version): the problem: pen pressure works ok but the RIGHT BUTTON doesnt work i cant change the brush size or do a zoom, but every thing else works ok. Image of 3dcoat loading and pen detected: https://ibb.co/vDmts5K Anyone can help.. iḿ using POPoS(ubuntu based). Quote Link to comment Share on other sites More sharing options...
New Member Solution EdanP Posted May 28, 2023 New Member Solution Report Share Posted May 28, 2023 This post was recognized by Carlosan! EdanP was awarded the badge 'Helpful' and 1 points. Hi! Just solved the problem today with a buddy so I thought I would drop the solution here. You have to run it as a terminal and make sure your COAT_MOUSE is set to your Huion mouse, while COAT_ERASER is your actual physical mouse, and your COAT_PEN is your stylus. Mine looks something like this Quote Link to comment Share on other sites More sharing options...
New Member abontav Posted June 17, 2023 Author New Member Report Share Posted June 17, 2023 Thanks!!! i'll give it a try!... Quote Link to comment Share on other sites More sharing options...
