Member pieralessi Posted April 25 Member Report Share Posted April 25 bandicam 2023-04-25 07-58-11-526.mp4 bandicam 2023-04-25 07-55-58-204.mp4 Quote Link to comment Share on other sites More sharing options...
Oleg_Shapo Posted April 25 Report Share Posted April 25 So, did everything work? Quote Link to comment Share on other sites More sharing options...
Member pieralessi Posted April 25 Author Member Report Share Posted April 25 NO Quote Link to comment Share on other sites More sharing options...
Oleg_Shapo Posted April 25 Report Share Posted April 25 7 minutes ago, pieralessi said: NO Should be turned off here. Quote Link to comment Share on other sites More sharing options...
Member pieralessi Posted April 25 Author Member Report Share Posted April 25 From the Udemy Course, the option is not active Quote Link to comment Share on other sites More sharing options...
Member pieralessi Posted April 25 Author Member Report Share Posted April 25 I activated the option and the problem persists Quote Link to comment Share on other sites More sharing options...
Oleg_Shapo Posted April 25 Report Share Posted April 25 26 minutes ago, pieralessi said: I activated the option and the problem persists The brush depth value must not be 0 Quote Link to comment Share on other sites More sharing options...
Member pieralessi Posted April 25 Author Member Report Share Posted April 25 my depth was 8% from scratch, I didn't move it, I fixed to 39% and the problem persist. Quote Link to comment Share on other sites More sharing options...
Oleg_Shapo Posted April 25 Report Share Posted April 25 7 minutes ago, pieralessi said: my depth was 8% from scratch, I didn't move it, I fixed to 39% and the problem persist. Then please let me feel the model. Quote Link to comment Share on other sites More sharing options...
Member pieralessi Posted April 25 Author Member Report Share Posted April 25 I closed and opened the program, the depth returned to 0%, I moved it to 100% and it worked, even 50% 1 Quote Link to comment Share on other sites More sharing options...
Member pieralessi Posted April 25 Author Member Report Share Posted April 25 bandicam 2023-04-25 10-55-15-778.mp4 bandicam 2023-04-25 10-53-54-346.mp4 New problem, I can't avoid no select leg layer Quote Link to comment Share on other sites More sharing options...
Member Solution pieralessi Posted April 25 Author Member Solution Report Share Posted April 25 Solved, autopick was selected Quote Link to comment Share on other sites More sharing options...
Member pieralessi Posted April 25 Author Member Report Share Posted April 25 NEW BUG! Tubes/muscle no works with paths in my PC bandicam 2023-04-25 12-17-25-838.mp4 In the course works bandicam 2023-04-25 12-16-13-993.mp4 Quote Link to comment Share on other sites More sharing options...
Oleg_Shapo Posted April 25 Report Share Posted April 25 17 minutes ago, pieralessi said: NEW BUG! Tubes/muscle no works with paths in my PC Check the visibility of curves in the Curve Tree Quote Link to comment Share on other sites More sharing options...
Member pieralessi Posted April 25 Author Member Report Share Posted April 25 Quote Link to comment Share on other sites More sharing options...
Oleg_Shapo Posted April 25 Report Share Posted April 25 This must be enabled. Quote Link to comment Share on other sites More sharing options...
Member pieralessi Posted April 25 Author Member Report Share Posted April 25 k, I didn't hide that Honestly, in Mac and Windows there is at least one problem with the commands or functions, it has been impossible for me to learn 3D Coat well, it is useless to use a program that although easy its tools do not work correctly or I have to discover some option that is not obvious or hidden, if I see that they work in a course and I follow the steps correctly, why doesn't it give me the same result? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 25 Report Share Posted April 25 On my version is working as expected too. if I see that they work in a course and I follow the steps correctly, why doesn't it give me the same result? Show in the course the layers panel. It is empty as default ? It is yours empty as well ? 1 Quote Link to comment Share on other sites More sharing options...
Member pieralessi Posted April 25 Author Member Report Share Posted April 25 If I am watching a course, the instructor is supposed to explain all the details, it has taken me a long time to learn the software because even when I have a problem, a lot of time is wasted waiting for explanations, I appreciate you taking your time to explain it but it should be the instructor of the course, unfortunately he decided not to answer my questions, he improvises too much and repeats the steps with mistakes a lot. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 25 Report Share Posted April 25 Pier: Thank you for reply, it's solved Quote Link to comment Share on other sites More sharing options...
Oleg_Shapo Posted April 25 Report Share Posted April 25 1 hour ago, pieralessi said: I appreciate you taking your time to explain it but it should be the instructor of the course Feel free to ask questions. You will be happy to help if there is a solution to the problem. 1 Quote Link to comment Share on other sites More sharing options...
Member pieralessi Posted April 26 Author Member Report Share Posted April 26 (edited) A curious situation, when I select the armor the Vox Hide tool is not in the settings but when I select for example the belt then I can locate it. On the course even with the armor selected if it appears. bandicam 2023-04-26 08-00-14-951.mp4 Edited April 26 by pieralessi Put video Quote Link to comment Share on other sites More sharing options...
Advanced Member Koray Posted April 26 Advanced Member Report Share Posted April 26 Vox hide is hidden in surface mode Quote Link to comment Share on other sites More sharing options...
Member pieralessi Posted April 26 Author Member Report Share Posted April 26 Both layers are in sculpt mode, Where are surface mode? Quote Link to comment Share on other sites More sharing options...
Advanced Member Koray Posted April 26 Advanced Member Report Share Posted April 26 (edited) This post was recognized by Carlosan! Koray was awarded the badge 'Helpful' and 1 points. when you look at individual layer names on the stack you'll see a V and an S. V is voxel mode, S is surface mode. The armor is in surface mode. Edited April 26 by Koray 1 Quote Link to comment Share on other sites More sharing options...
Member pieralessi Posted April 26 Author Member Report Share Posted April 26 I'll try it, Thank you Quote Link to comment Share on other sites More sharing options...
Member pieralessi Posted May 17 Author Member Report Share Posted May 17 What am I supposed to put here? Quote Link to comment Share on other sites More sharing options...
Member pieralessi Posted May 17 Author Member Report Share Posted May 17 This happened in my powerful PC Quote Link to comment Share on other sites More sharing options...
Oleg_Shapo Posted May 17 Report Share Posted May 17 51 minutes ago, pieralessi said: This happened in my powerful PC Try specifying fewer polygons. Or describe the steps to repeat this on my computer. Quote Link to comment Share on other sites More sharing options...
Member pieralessi Posted May 17 Author Member Report Share Posted May 17 How many polygons is low? Quote Link to comment Share on other sites More sharing options...
