  • 0
Merge vertices/edges together
DustyShinigami
Question
2 answers to this question
  • 1
Carlosan
AbnRanger was awarded the badge 'Great Support' and 1 points.
On 7/8/2023 at 12:57 AM, DustyShinigami said:
Hi
Is it possible to merge a ring of edges/vertices together instead of having to manually move each one until they snap? Like these two edges...?
Thanks
Yes, you can. However, you first need to switch to vertex mode > RMB over the model (or pick the tool from the Tool Panel) and choose WELD VERTICES. This will let you weld selected vertices to others that are within the range you specify in the Tool Options panel, while this tool is active.
Answer this question...
