Advanced Member 3dioot Posted July 3, 2009 Advanced Member Report Share Posted July 3, 2009 Wow! great idea about hide!I am thinking that freese could be done in similar way. And color in future. I am happy you like this idea. I have posted this idea before with a more elaborate explanation so just in case that got missed (which it seems to) here is how id love for it to work. - It acts like the extrude or sphere brush (extrude would be nicer but sphere is probably faster) but instead of adding or removing it hides by default - All the lasso tools hide chunks by default - Holding ctrl UNHIDES what you are brushing or lassoing around. So this means you can easily brush or lasso parts of your mesh IN and OUT of hiding without ever needing to go search for an unhide button. The button should exist but you should not be dependant on it. ------------- I dont see how this is suitable for masking though? Masking should have "transitional areas". Area's that are in between 0 and 100% influence. Otherwise the masking will really be too crude to use effectively. 3dioot Link to comment Share on other sites More sharing options...
Advanced Member kay_Eva Posted July 3, 2009 Advanced Member Report Share Posted July 3, 2009 Is there any way to get the voxel/surface sculpting brush circular indicator to reappear once it disappears? Link to comment Share on other sites More sharing options...
Contributor LJB Posted July 3, 2009 Contributor Report Share Posted July 3, 2009 Is there any way to get the voxel/surface sculpting brush circular indicator to reappear once it disappears? Capslock? Link to comment Share on other sites More sharing options...
philnolan3d Posted July 3, 2009 Report Share Posted July 3, 2009 Yeah, hitting Caps Lock is the only way I know of to make it disappear or reappear. Link to comment Share on other sites More sharing options...
Advanced Member kay_Eva Posted July 4, 2009 Advanced Member Report Share Posted July 4, 2009 thanks guys, btw I had been wondering why the cursor was disappearing for months, and then as soon as I post about it I figured it out on my own literally 2 minutes later, AND I get 2 posts that answer the question for me kind of funny just like the way I bought a pair of headphones off of Newegg and then as soon as I receive them the price is cut in half lol (I sent them back) Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted July 4, 2009 Author Report Share Posted July 4, 2009 IMPORTANT! I found the reason of constant slowdowns in some cases that was previously reported. I will make update but for now turn off bottom hints using close icon to avoid problem. Link to comment Share on other sites More sharing options...
philnolan3d Posted July 4, 2009 Report Share Posted July 4, 2009 Forgive my ignorance but what really is the purpose in the new Surface mode? Is it just that it's faster for making more general sculpting changes without messing up the details too much or is there something else? Link to comment Share on other sites More sharing options...
Contributor artman Posted July 4, 2009 Contributor Report Share Posted July 4, 2009 Forgive my ignorance but what really is the purpose in the new Surface mode? Is it just that it's faster for making more general sculpting changes without messing up the details too much or is there something else? For one thing, it allows smoothing of thin surfaces without creating holes,which was really important. Also I think it is much faster than previous work with surface tools because voxel-surface transfer is done prior and after sculpting instead of after each strokes.When I use surface tools with older way there always was a small delay after each strokes even if I got a pretty good machine.But now,in new surface mode,when I use sf.clay brush it is much faster and responsive. Hope that helps. Link to comment Share on other sites More sharing options...
Advanced Member 3dioot Posted July 4, 2009 Advanced Member Report Share Posted July 4, 2009 Yep what artman says. I dont think it has a specific purpose at this point though. Its probably just an experiment on Andrew's side to explore whats possible. What i would like to see (and again most of this technology is allready created by Andrew) is a "from voxel to mesh sculpting room" conversion. This would be the workflow. - First you create your voxel sculpt to the level you like or how far your workstation can get you in the voxel room (using whatever tools you like, pure voxel or the hybrid sf ones in the voxel room) - You choose autoretop (which would offer a target polycount in steps. See reason a bit further down) - Your autoretoped quad base mesh is loaded into the mesh sculpting room - Subdivision levels are automatically added to your quad mesh to reach a polygon count equal (or slightly above) your original voxel skin (so its important that autoretop allows you to choose in steps compared to your voxel polygon count. In other words you should get the option to create a basemesh thats 1/4 1/16 and so on) - All the detail from your voxel sculpt will be reprojected (the mesh will be literally displaced) - You can now sculpt on this mesh in a similair way as you can in zbrush or mudbox + You will have subdiv levels to step up and down in (since autoretop created a low res quad base for you) + you will have the ability to add subdiv levels (this needs to be added) + You will be able to sculpt in your extreme hf details While this results in a somewhat lineair workflow i think that by the time you are ready for pores there will not be form changes that are so big you would need voxels to support it. Since you will be able to step down in subdiv level there will be alot of freedom to make proportional changes anyway which usually dont require topology changes. Offcourse there always is the option of using this mesh to generate a voxel volume from if you feel you have to. 3dioot PS Offcourse this doesnt change my opinion that 3dcoat should really push voxel sculpting since its the holy grail of digital sculpting. For the time being however i think this can be a very usefull workflow which would open up the sculpting of 3dcoat to be used in production today. Link to comment Share on other sites More sharing options...
philnolan3d Posted July 4, 2009 Report Share Posted July 4, 2009 For one thing, it allows smoothing of thin surfaces without creating holes,which was really important.Also I think it is much faster than previous work with surface tools because voxel-surface transfer is done prior and after sculpting instead of after each strokes.When I use surface tools with older way there always was a small delay after each strokes even if I got a pretty good machine.But now,in new surface mode,when I use sf.clay brush it is much faster and responsive. OK I can see that. On an unrelated note... When merging voxels to DP now there's a Normal Map layer created. Painting on that layer makes a mess, so I assume we're no supposed to do it. If that's the case the layer should be automatically locked. Link to comment Share on other sites More sharing options...
Advanced Member kay_Eva Posted July 4, 2009 Advanced Member Report Share Posted July 4, 2009 OK I can see that. On an unrelated note... When merging voxels to DP now there's a Normal Map layer created. Painting on that layer makes a mess, so I assume we're no supposed to do it. If that's the case the layer should be automatically locked. what do you mean locked? and why? obviously you wouldn't want to paint specular/diffuse on your normal map image? But you might want to merge it to another normal map image, or manipulate it in some other manner (idk I'm no expert) Link to comment Share on other sites More sharing options...
Contributor BeatKitano Posted July 4, 2009 Contributor Report Share Posted July 4, 2009 Small bug in 3.00.08c cuda dx64 : if you hide the brush tray, you can't use shortcuts for brushes. (surface mode is really nice, with a multi res voxel sculpting it would beat zbrush and mudbox. This mode is really close to the "natural feel" sculpting of those apps) Link to comment Share on other sites More sharing options...
philnolan3d Posted July 4, 2009 Report Share Posted July 4, 2009 what do you mean locked? and why? obviously you wouldn't want to paint specular/diffuse on your normal map image? But you might want to merge it to another normal map image, or manipulate it in some other manner (idk I'm no expert) Here's a quick video. If you try to paint on that NormalMap layer the spec does nothing, the normal painting does nothing, but if you try color it makes a weird mess. If I click "Quadrangulate and paint" the first thing I will want to do after the process finishes, is paint. So therefore it should be at least hidden, along with layer 0, so I can't accidentally mess it up. http://screencast.com/t/oCO0pCTn Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted July 4, 2009 Applink Developer Report Share Posted July 4, 2009 I like you 3dioot. Your ideas are very good. Just keep it coming Link to comment Share on other sites More sharing options...
Contributor artman Posted July 4, 2009 Contributor Report Share Posted July 4, 2009 New surface smooth is really a sculpting tool in itself,like a sort of microscrape. The more I use it the more I find uses to it. . Thanx for implementing this, it is a very welcomed addition.Especialy for hardsurface work. EDIT: also,I think I found out how you could make voxel based multiresolution.It is very funny. The principle is based on the idea that going into a lower resolution would only be used as a simulation to record brush actions and that would after be reproduced to the hires voxel level through an operation without display onscreen . example: let's say I have a voxel sphere hitting 60000 polys ,I sculpt a little then...I increase resolution using actual "increase res" function to make some finner details .Now I'm at level 2(let's call it level2) and I make some finer details.I do my thing,I'm happy then...I decide to go back to previous level to use the MOVE brush with a big radius and all. Here is how it works: As soon as I press the degrade button 3DCoat make an usual degrade function (But it automatically save the file to a temp .3b file before). At this point when the user is now working on the degraded model ,3DCoat automatically starts recording the camera moves and the brush strokes.The user make changes with the move brush and when he's done and press the "increase res" button again,3DCoat close the file,reopen the temp .3b and replays all the brushes actions on the higher resolution model.Of course the replays of the brushes actions are done without display on screen ,as an invisible process.Of course this operation will create a delay ,but there is also a delay when you skip resolutions in ZB.And since no display on screen is involved you can probably make this a fast operation.At least, I think .Anyway,I hope it dont sound too stupid,it was very funny to think of. Link to comment Share on other sites More sharing options...
Advanced Member Frankie Posted July 5, 2009 Advanced Member Report Share Posted July 5, 2009 IMPORTANT!I found the reason of constant slowdowns in some cases that was previously reported. I will make update but for now turn off bottom hints using close icon to avoid problem. I just tested it and indeed it works fine now ! wonderful news, thanks Andrew. A few minor things I think should be addressed in one of the next versions: .Pen presets should each remember size, depth and pressure mode settings (size/opacity depends on presure...etc) .Brush, airbrush and eraser should remember the associated pen preset (seems to work sometimes, heratically, not sure about this actually working) .When opening 3dc, it should remember the last tool configurations (brush mode, pen preset for Brush, airbrush and eraser) .When opening a project, it should remember the last camera position in that project Also I remember at some point you mentionned there would be a way to use the clone brush with a background picture (to clone from the pictude onto an object). Is this implemented ? I cannot find it. Thanks alot for everything, Franck. Link to comment Share on other sites More sharing options...
Advanced Member Paint Guy Posted July 5, 2009 Advanced Member Report Share Posted July 5, 2009 Any idea when 3DC 3.00.08 Mac will be available. Link to comment Share on other sites More sharing options...
Advanced Member jedwards Posted July 5, 2009 Advanced Member Report Share Posted July 5, 2009 Any idea when 3DC 3.00.08 Mac will be available. It already is... I'm using .08C right now. Link to comment Share on other sites More sharing options...
Advanced Member Paint Guy Posted July 6, 2009 Advanced Member Report Share Posted July 6, 2009 It already is... I'm using .08C right now. Oops, I was trying to download it from the downloads section. Now I have it Thanks! SMOOTH BUTTON Where did the default go to allow me to hold the "Shift" key down to smooth out my sculpt?? Somebody mentioned allowing the smooth to be separate for each brush so for example if you were sculpting fine wrinkles for example using a small # 1 brush, then the smooth would use the same #1 size of brush, but if you were using a large #6 brush, then the smoothing would use the large #6 brush and be more pronounced. This sounded like a great idea. INCREASING/DECREASING SUBDIVISION LEVELS in PER-PIXEL and VOXEL SCULPTING Any progress Andrew on adding the ability to increase/decrease subdivisions in Voxels and Per Pixel? Thanks Link to comment Share on other sites More sharing options...
Javis Posted July 6, 2009 Report Share Posted July 6, 2009 The smooth button is just added - You can still hold shift to smooth. I wouldn't key voxel resolution as subdivisions - That is strictly for polygons. I would key it more as density of voxels. I spoke to Andrew a week or so ago, he told me about a number of things on his to-do list, and luckily, this is one of them! I'm sure we'll see it soon. Link to comment Share on other sites More sharing options...
Advanced Member Paint Guy Posted July 6, 2009 Advanced Member Report Share Posted July 6, 2009 The smooth button is just added - You can still hold shift to smooth. Thanks, Geothefaust, I was panicking because I was using the clay brush and "Smooth" wasn't working with the "Clay" brush and I thought it was the same for all. Is "Smooth" not supposed to work with the clay brush too? I wouldn't key voxel resolution as subdivisions - That is strictly for polygons. I would key it more as density of voxels. I was just trying to describe it but you are right, so I hope there is the ability "SOON" to allow us to increase and decrease density of Voxels and increase and decrease polygons in Per-Pixel Sculpting. I spoke to Andrew a week or so ago, he told me about a number of things on his to-do list, and luckily, this is one of them! I'm sure we'll see it soon. This is great and one of the most important features IMO. Mesh Extraction I also mentioned to Andrew the need to incorporate "Mesh Extraction" into 3DCoat as it's very fast and efficient for creating clothes, helmets, gloves and many other objects from any piece of geometry. (see link) http://www.pixologic.com/docs/index.php/Mesh_Extraction I tried using the "Extract Skin" feature in Voxels, but it extracts the whole object and not just a part of it. I think being able to paint the area you want to extract (like ZBrush) is a lot faster and allows you to extract a selected area rather than extracting the whole object like the extract skin currently does. Also if you use "Extract Skin" and then cut away material the edges come to a point whereas in ZBrush when you use mesh extraction the part that is extracted has a square edge so it looks more realistic like the edge of armor or the edge of clothing like a jacket. If there is another method for extracting in 3DCoat that is better then please let me know. Thanks Link to comment Share on other sites More sharing options...
Advanced Member jedwards Posted July 6, 2009 Advanced Member Report Share Posted July 6, 2009 If there is another method for extracting in 3DCoat that is better then please let me know. Thanks The Copy brush does this. Create a new empty voxel layer, and use it as your active layer, then whatever you paint over in the viewport with the Copy brush will show up there. I like this much better than mesh extraction, which I use a lot in zbrush. Link to comment Share on other sites More sharing options...
Advanced Member kay_Eva Posted July 6, 2009 Advanced Member Report Share Posted July 6, 2009 lol there is a copy brush ? Link to comment Share on other sites More sharing options...
Advanced Member Paint Guy Posted July 6, 2009 Advanced Member Report Share Posted July 6, 2009 The Copy brush does this. Create a new empty voxel layer, and use it as your active layer, then whatever you paint over in the viewport with the Copy brush will show up there. I like this much better than mesh extraction, which I use a lot in zbrush. Thanks jedwards. I did a test using the "Copy" tool and although this tool has a lot of potential I didn't find it very useful in it's current state. For example using the "Copy" tool I created a "Vest" but the results were far from impressive. It would be too much work IMO to make proper armor, clothing, helmets or anything with the COPY tool in it's current state. I made a request in the Feature Requests area with a list of what the problems were and some possible solutions to make this tool Great! http://www.3d-coat.com/forum/index.php?showtopic=2965 Name Change? I also think a name change would be very helpful. When I think of a copy. I think of an identical "duplicate", and not a tool with the possibility for making parts from a current surface (armor, helmets, clothing, etc.) then I think of it more like extraction rather than copy so maybe it could be called something different like "Extract" or "Extract Surface" as this helps me to understand what the tool is used for, whereas copy is confusing and too much like duplicate. Thanks Link to comment Share on other sites More sharing options...
Contributor artman Posted July 6, 2009 Contributor Report Share Posted July 6, 2009 Thanks jedwards. I did a test of the "Copy" tool and found that it is not very useful in it's current state. For example I created a "Vest" with the copy tool but the results were far from impressive. It would be too much work IMO to make proper armor, clothing, helmets or anything with the current tool. I made a request in the Feature Requests area with a list of what the problems were and how they could be possibly fixed here: http://www.3d-coat.com/forum/index.php?showtopic=2965Thanks Use technique with Cloth function,it does exactly ALL you're asking, -(In retopo room) create the vest or armor piece with your favorite retopo method press subdivide a couple of time -Go back to voxel room and select cloth function select "pick from retopo" -Set a thickness value and press ENTER (if you set a negative value it will still make an extrusion but if you hold Ctrl while pressing Enter you will get a substraction instead) Shazam Link to comment Share on other sites More sharing options...
