Merge object Nightmare
Juan Carlos Montes
Hi Andrew I get this problem with one of my models
I paint most of my model and I notice I make a mistake with the pants UV
So I erase the material of the pants ( That also delete the model no?)
I fix my uv map in blender and export only the pants.
Then I use merge Object and everything seems to be normal and perfect , I texture the pants and save my model
and then I all most cry wen I open my file and see the model.
The Uv of the pants merge with the face and the pants looks invisible.
That was on 3dcoat 3.00.08C
I did something Wrong?
seems you made all right.
I reproduced problem with
merge cube
merge sphere
delete cube
merge cube
save
exit
open
only cube visible...
I seeking solution.
Thanks Andrew!
That was Fast.
I will try later when I get Back home.
Thanks!
I test this new Update an is Working perfect, No problems With Merge Object.
Thanks.
