Modeling/Retopo lasso selection problem.
Go to solution Solved by Jfredd,
  • Solution
Posted (edited)
Carlosan
Jfredd was awarded the badge 'Great Content' and 1 points.
Evil_Weasel (Discord) passed along workarounds for this, in case others are experiencing the same problem.
  • Create a new, empty UV set and switch to it in the tool bar, then the select tool behaves normally
    or
  • Manually de-select the UV island in the UV Preview after selecting the vertices.
Neither is the ideal/straightforward way, but it gets us through.
It doesn't overshadow my thankfulness to the 3d-coat team  for such great software :)
Edited by Jfredd
