  • 0
Update Error
Sui
Question
An error stating Insufficient Space occurred when I tried to update from 2023.40 to 2024.15. My system drive has around 80GB, and installing drive has 93. What is the reason for this error and how to fix it? My software and file open up correctly but I am not sure if there is any hidden issure.
3 answers to this question
  • 0
Yes, reinstall will be the better option
Its difficult to said because some many changes was featured in between versions.
Edit > Relocate 3DC's data let you select any folder with your own content. It can be on other disk non C:
  • 0
Try installing on disk C:\
  • 0
But there is no option letting me choose installation path. Should I just reinstall the soft?
BTW, after the issue, I tried downgrading back to 2023.40 on the website, just to prevent any hidden problems, failed though. Can I actually downgrade to 2023 and also download a copy of 2024 while keeping the same settings? My setting folder is extrodinarily large(122GB). Copy&paste it would be a pain, so I just wonder if that is possible.
Answer this question...
