  • 0
2D-Paint Absolute Depth Value [SOLVED]
Inmeining
Question
  • New Member
Hi all
I was wondering if there is a Way to set an absolute Depth Value to the 2D-Paint Tool.
My current problem is, if i Start painting with for example a radius of 20 and depth of 50%, and then change at least one of those values, i'm not at the same depth as before.
So is there a way to keep the Depth Value while changing the brush's radius? It also doesn't have to be the 2D-Paint tool. This one just seemed to be the most promising.
Thanks in advance
2 answers to this question
  • 1
Carlosan
Sui was awarded the badge 'Helpful' and 1 points.
Yes you can find a "lock" icon on the left of Depth in the top bar. Toggling that on will keep the depth the same while adjusting radius.image.thumb.png.9793b874cf628b4da884b60cfc19de7b.png
  • 0
  • New Member
Wow, you're awsome, thanks a lot for the tip :D
Answer this question...
