New Member chenxy Posted June 9 New Member Share Posted June 9 This is a good software, very easy to handle and has the most comprehensive modelling untility, I don't have to switch to other software to complete a model. But recently I had a problem.3dcoat seemed to cause an abrupt Gpu load rise to around 70% whenever I piant, sculpt or even move the viewport, and the PC was roaring as it was dissipating the heat. This was not the case in blender or zbrush, which keeps gpu load 10%~40% or <10%, and the computing was quiet most of the time. How should I configure the setting to avoid this? The gpu I'm using was AMD 780m core graphic card. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 9 Share Posted June 9 Hi Try limiting FPS on Preferences Quote Link to comment Share on other sites More sharing options...
New Member chenxy Posted June 10 Author New Member Share Posted June 10 21 hours ago, Carlosan said: Hi Try limiting FPS on Preferences It worked! thanks! 1 Quote Link to comment Share on other sites More sharing options...
