Any way to disable dragging (when using a stylus) in Quick Access menu?
Oasin
  • New Member
Hi, just trying out this amazing piece of software.
I'm doing some sculpting and found the "Quick Access" menu (the one that appears when I press [space]) quite handy. But I often fail to select a tool with my stylus as it recognizes my input as (a very short) dragging. This behaviour can get quite annoying when in a flush of tool switching. Is there any way to disable dragging when interacting this menu? Or, is there some setting I can tweak to specify the "minimum distance traveled before input event is taken as dragging when accessing the UI"?
with regards.
