[Bug] Exporting Textures with correct Alpha
Hello, I want to Export Albedo textures through Export/ColorAlbedoMap Without Padding. (Edit-Preferences-Padding->Never)
I want to export textures with full transparent Alpha background in the blank space without UV information, Instead everytime I export the color Albedo textures, they are exported with a somewhat gray alpha value in those blank spaces, not being fully transparent. I tried .png .tga and .tiff and it's the same result.
How can I export a clean texture with 100% opacity in the unused sections?
Thanks!
Hi
Hide Layer0 to save transparency
If you erase the paint, things still bake just fine. However, the transparent areas created will be baked as alpha/trans.
Also, if you hide Layer 0, it bakes fine and entirely with alpha/trans, whereas any other layer doesn't contain color data.
*Layer0: avoid painting it for any purpose but transparency.
I'm using the latest build 2024.20 I downgradde to 2024.17
And the problem persists.
Also yeahit's hidden but your export is correct, your alpha is black and white, mine is grey and white.
(Also why your channel is named "Alpha" and mine is named "Alpha 1"?)
Thanks!
Posted (edited)
It's just a cube with Uvs, it happens with all the projects I work on 3DCoat
Maybe I need to chek something on preferences? it seems weird because I don't even know why that gray value is showing in the alpha, don't know where is coming from, could it be residue from the padding?
Edit: I mainly work on 3Dcoat for Unlit Handpainted Textures, just want the albedo texture, I don't need Roughness, Depth etc.
Cube.3b
Edited by DiJa
clarification
Posted (edited)
Hello Carlosan, Uninstalled and Reinstalled 3DCoat, reset all settings, hotkeys, windows, prefs
Problem persist.
I haven't changed anything from the original install, just some hotkeys and screen position, background color to 50% gray, I just use the perpixel painting ulitlity as I stated I just use 3Dcoat for handpaint.
I see you get the export as it should be.
The only workaround I found is using Sync Layer with external editor, and I save it with Photoshop instead of exporting with 3DCoat, which is ok but it slows the process and requires me to have PS.
My settings if it helps:
I'm using a cintiq 21 UX 2nd Gen and a Wacom Intuos Pro
64GB
Intel i7-9700K @3.7GHz 12 cores
Nvidia RTX 3070
Edited by DiJa
Found it, thanks for point it up
It add extra level of gray to the alpha
*you can add Gimp as external 2d app on Preferences
  • Carlosan changed the title to [Bug] Exporting Textures with correct Alpha
