Member Szaibot Posted June 27 Member Share Posted June 27 Hi, Vox layer tool after applied creates empty layer ;/ Vox Extrude works fine with the same selection 3DCoat 2024.20 2024-06-27 14-02-15.mp4 version 2024.20 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 27 Share Posted June 27 Hi Are you using latest version ? Testing it, I found it is working fine Quote Link to comment Share on other sites More sharing options...
Member Szaibot Posted June 27 Author Member Share Posted June 27 version 2024.20 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 27 Share Posted June 27 Sorry, still I cant replicate Try other settings Quote Link to comment Share on other sites More sharing options...
Advanced Member Elemeno Posted June 27 Advanced Member Share Posted June 27 1 hour ago, Szaibot said: version 2024.20 happening to me , on the tools options theres a create as surface option , use that and then voxelize it after as a workaround 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member Elemeno Posted June 27 Advanced Member Share Posted June 27 Just now, Elemeno said: happening to me , on the tools options theres a create as surface option , use that and then voxelize it after as a workaround even create as surface doesnt work ..... bug confirmed 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 27 Share Posted June 27 As workaround also can use Coat tool 1 Quote Link to comment Share on other sites More sharing options...
New Member tospeed Posted July 22 New Member Share Posted July 22 (edited) It's 2024.23 versionI'm experiencing the same problemIf you draw a freeze area in voxlayer, it doesn't work. But shape freeze worked 2024.20 is worked Edited July 22 by tospeed Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 22 Share Posted July 22 Testing 2024.23 Found it working as expected, try using it on any default mesh. Quote Link to comment Share on other sites More sharing options...
