Member Szaibot Posted July 11 Member Share Posted July 11 (edited) Hi, I would like to render project for painting on in other software but after raising resolution, render folder is empty (only render on 1920x985, which is too small for my usage) Is it a bug, or I'm doing something wrong? Generic_Figure_Male.3b_ - 3DCoat 2024.22 2024-07-11 10-56-52.mp4 (testes on multiple 3d coat version 2024.22; 2024.16) Edited July 11 by Szaibot Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted July 11 Share Posted July 11 1 hour ago, Szaibot said: Is it a bug, or I'm doing something wrong? Hello! When you click the Render button does Explorer open? What's in the folder after clicking Show Folder? Quote Link to comment Share on other sites More sharing options...
Advanced Member Elemeno Posted July 11 Advanced Member Share Posted July 11 4 hours ago, Szaibot said: Hi, I would like to render project for painting on in other software but after raising resolution, render folder is empty (only render on 1920x985, which is too small for my usage) Is it a bug, or I'm doing something wrong? Generic_Figure_Male.3b_ - 3DCoat 2024.22 2024-07-11 10-56-52.mp4 8.77 MB · 0 downloads (testes on multiple 3d coat version 2024.22; 2024.16) are you using the learning license? Quote Link to comment Share on other sites More sharing options...
Member Szaibot Posted July 11 Author Member Share Posted July 11 (edited) 3 hours ago, Oleg Shapov said: Hello! When you click the Render button does Explorer open? What's in the folder after clicking Show Folder? Yes it opens But I have found a solution. First you have to select lowest resolution that works, then crop it do desire aspect. Click ok, then go back and from drop down select what u want. And it will export a selected size and lower rays per frame Edited July 11 by Szaibot Quote Link to comment Share on other sites More sharing options...
Member Szaibot Posted July 11 Author Member Share Posted July 11 1 hour ago, Elemeno said: are you using the learning license? no. full version Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted July 12 Share Posted July 12 On 7/11/2024 at 5:16 PM, Szaibot said: First you have to select lowest resolution that works, then crop it do desire aspect. But it shouldn't work like that. You can immediately select the desired resolution. Reported to developer. Quote Link to comment Share on other sites More sharing options...
