Posted
Hi,
the applink for Blender 4.2 isn't working - when you try to install get the following message - No module named 'io_COAT3D'
  • Replies 104
  • Created
  • Last Reply
Top Posters In This Topic
  • Britain
    30
  • Simon-telezhkin
    7
  • AbnRanger
    5
Posted
Hi, try this
Posted
Thanks - working now
  • New Member
Posted
Sending from Blender 4.2 to 3d coat 2024.23 was fine but I've encountered this error in Windows when pressing the "get back" button. Is this because the "addons" folder in drive c now becomes "addons_core" in blender 4.2?
  • New Member
Posted
Can you please explain, what was the full process? Because I tried this, but perhaps in wrong way.
Do we need just change the text in installed addon? Should we uninstall addon or reopen blender or something else?
Posted
So, it installs and the plugin will send a file to 3dcoat after the edits to the files, but now a simple per pixel paint cube with a few strokes on it, will give an error when GetBack is used in Blender.
The error is :-
  File "C:\Users\username\AppData\Roaming\Blender Foundation\Blender\4.2\extensions\blender_org\coat_applink\tex.py", line 331, in createnodes
    group_tree.outputs.new("NodeSocketColor", "Color")
AttributeError: 'ShaderNodeTree' object has no attribute 'outputs'
Note: The version of the plugin supplied when updating 3ds to the latest version is ONLY 4.9.34  This is not the latest version. The one provided with Blender 4.2 (and 4.3 alpha) is 4.9.37, which is the one I have, and which still does not work.
Posted
Hi, having made the code changes as per suggestion, the add-on installed & assumed everything was working but when using the add-on, I send to 3DC and nothing appears - so it's not working. 3DC could be a really great 'companion' as Grant Abbot stated in his recent YT but without this add-on fully working plus a few new features such as a better gradient tool, masking based on heightmaps, it'll only remain a small user base, which is sad.
  • 3DCoat Developer
Posted
I am working over compatibility, but really, in 4.2 they changed the whole structure of files, so nothing may work. But of course, I will fix it in next build (24). This is first priory.
  • 3DCoat Developer
Posted
The 2024.24 released with the Blender 4.2 support.
Posted
Hello, I have a problem:
2024_20 is ok.
2024_21 does not start
2024_22 is ok.
2024_23 does not start
2024_24 does not start
I would like to test Blender 4.2 and 3DCoat 2024_24.
Please help!
Skaties..
Posted (edited)
I don´t understand this addon at all.
I am using the Version which 3Dcoat 2024.24 installed; 5.0.0
I click on the Send button
I click into 3DCOAT and see this one;
539961775_Screenshot-2024-07-2514_14_51.thumb.png.57c2acc38a46e5398b9516f0b7220191.png
I click OK and the Mesh is imported into 3DCoat.
1040879459_Screenshot-2024-07-2514_14_58.thumb.png.ef3784a5e9f77c4cc701f11e6112651d.png
I paint a bit on it and when trying to send it back to Blender, it seems this Addon is not working and you can´t use the Export to Blender Function.
I have to use Open in external App instead.
I now have 10 temporary fbx files residing in the applink objects folder... (it only goes up)
I click export and i don´t know why but 3Dcoat decides i want Blender Cycles (no, how to save a new preset for the Blender export?)
1597537186_Screenshot-2024-07-2514_15_31.thumb.png.b05d054ec7e0fde6676b02516d6b3357.png
I get back a new mesh which is white and has no Textures.
1113691380_Screenshot-2024-07-2514_26_36.thumb.png.d8764c468b3e580150b30ea1c5994aff.png
1. Is there no cleanup happening in that exchange folder?
2. the user expects to be able to use the  The Export TO  > Blender way.
3. I just want to sent textures and not get additional  Meshes like _Suzanne| _cube added into my Blender File every time.
4.Is this the correct path? That is what seems to work halfway;
C:\Users\my personal loginname\Documents\AppLinks\3D-Coat\Exchange\
EDIT2: Three Images are apparently imported but they are not connected nor available inside the new random material/ shader.
2020557036_Screenshot-2024-07-2514_49_43.thumb.png.41e1600632e08ca9bf56c6a26b96a59f.png
Edited by myclay
added number of current 3DCoat install, added shader preview of material and image editor images
Posted
42 minutes ago, Carlosan said:
Are you following this steps ?
I tried to follow the described steps from Ctc_nick multiple times, it isn´t working.
  • Moderator
Posted
I know it's frustrating and thank you for helping by pointing out the exact issues you are having. However, please be patient because 4.2 really changed the way addons/extensions are handled, and I personally get emails from other addon vendors (from whom I purchased Blender Addons, such as AutoRig Pro and others), stating they are working all the kinks out, too.
Posted
Andrew mentioned that 2024 24 now has blender support. Is there a way to get this for testing? I dont want to update my stable version to an Alpha version.
Thanks
